Hello The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens. Try using a lens cleaner to remove dirt and clean lens. Also i read an article that using a wireless controler can also cause freezing of the blue ray.
there could be a possible error with your disk reader/ blu ray. If you still have it under warrenty get a new one, if not call up playstation and try and sort something out.
This is a common problem on the ps3 unfortunately and is caused by a faulty blue-ray drive. Unit will have to go back to Sony for service.
You should try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
However if this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.
Hope this helps. Please remember to rate my answer. Many Thanks.
When I had a similar issue with my PS2 (GT4 would not load) it was because the disk-reading laser was misaligned. That happened after using the system for many years, so if your system is new, maybe you can skip to the 2nd part of my answer. A slight misalignment could mean that the disk is still read, but the process takes longer. If COD5 requires frequent access to the disk when booting up - as GT4-, that might explain why other games load properly and COD5 doesn't.
Other potential problems: scratched disk (visible scratches), dirty disk (you can clean with a cloth, sweeping radially from the center to the border of the disk), problem with the COD5 data installed in your PS3 hard disk (try reinstalling the game).
The only way to do that is buy the game from the playstation store and download it.
Otherwise would be just to easy to rent the game, load it in the HDD and play....
try picking up a lens cleaning disk. they have brushes on the bottom that clean your lens. you put the alcohol water solution on the rushes and then insert it into the drive of the ps3. that may work if you have the same problem with all your disks. if you don't have a problem with all your disks, it may be that your savegame is corrupt and you need to start a new one.
