Question about GE Refrigerators
GE Profile Mdle PSC25SGSC SS Ser #FL410278 about 4 years old. Problem: Freezer gets warm - ice melts in ice tray and drips down and freezes in big icecle as the system recovers by itself and freezes again. It will then make ice and a day or less later, start to melt and drip then repeat again with no apparent timing cycle. It may make and keep ice for two days and maybe not. Of course the refrig gets correcspondingly warmer at the same time. The temp readings appear false as it may say -1 on freezer readout and melting will be going on. If I unplug, wait 30 sec replug in again and do a system reset with the freezer and refrig buttons, it will give a new temp reading, say 45 for the refrig and 11 for the freezer, but freezer will be melting in actuallity. Diagnostic: Doing a diagnostic of 0 on freezer side and a 3 on refrig side, I get a FAILURE or F reading. According to my manual this is a failure of the temp control panel to the dispenser board communication. All other diagnostics come up as P or PASSED. Other Note: I only hear two fans come on during fan check, which is Code 1 and 1 called fan speed test. They run for 10 seconds each during the test like it is supposed to , but the manual does not say how many fans the refrigerator has. Both fans that run during the test sound like they are in the refrig unit not in the freezer unit. Prior to this problem, I used to hear a fan down low behind the freezer area make a clicking noise like the blade was hitting something. Now it makes no sound, so I don't know if the fan is even coming on. What I would like to know: What does fail on code 0 3 mean. I do not know what the temp contro panel is -- I assume it is the control panel on upper part of the refrig side that I st the temps and use to run the diagnostics. Also, what is the dispenser board communication? Question 2: What about the fan? Question 3: Do you recommend fixing it and if I buy a new one will it take significantly less electricity to operate and will the new refrigerators be built as well as this one? Thank you. Sorry I got this so word(y).
  • 4,059 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp.
With an ohm meter it should show continuity when cold and none when warm.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located on the back. It's part 801 in this diagram and parts list.
Based on the other diagrams you have a fan in the freezer (evaporator fan) and one underneath near the compressor. Condenser fan. here is a link to your diagrams. The sealed system and motherboard is where the control is.
Posted on Jul 11, 2010
  • 1 more comment
  • davidglassbl Jul 11, 2010
    Thanks for your reply. I got the first three paragraphs ok , but I think the first parts of paragraph 4 are missing can you please resend. Also did you address teh error code failure I get when I do diagnostic code 0 -- 3?
    David
  • davidglassbl Jul 17, 2010
    Please tell me what the diagnostic code failed on 0 and means. Do I need to replace a part?.
    Thanks, David
    Sorry I meant to ask you what code 0 and 1 failure means. Do I need to replace a part?
    Thanks David
My GE side by side refrigerator model PSC25SGSC has a problem. It makes ice fine. But sometime, all the ice cubes melted, along with the food on the top shelf. After I turned the ice maker on and off, it...
Ok this sounds like your mainboard is about to go out, its causing intermittment cooling issues, board runs about $150-200.As long as you dont have any frost buidup in the back of the freezer, if not definitely the board. If you need any further assistance let me know.
Sean
Mar 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Ice melts water drips out of icemaker & freezes in a column
If your model is doing that I would consider looking at the defrost components. Look inside back of freezer for frost building a thin layer on the rear wall. If yes then unplug and remove the rear panel in back of freezer and defrost with a hair dryer. You have and air circulation problem or a defrost problem. Sounds like it's trying to defrost but we need to have a look at the evaporator coils in the rear behind that cover. First let me know what you find and we will go from there, Thanks Sea breeze
Aug 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water build up back of freezer inside drips to bottom and leaks from under door.Looks like their is some sort of tray with hole in back then it overflows drips to bottom of freezer some of water freezes...
Our GE Profile leaked from the freezer door and this is what I was told by a service man to try before he came and it worked. There should be a "well" on the bottom of your freezer floor where the water runs when it defrosts. Yours is probably now covered with a sheet of ice. You can melt the ice with a hairdryer using dry towels to soak up the water as you work or really hot wet rags and ring them out in the sink. After all the ice is removed pour a small amount of warm water into the "well" and stick your finger in there and "plunge" it - like you would a clogged toilet - with your finger. This will purge the ice that blocked the drain. Check on this every couple of months to make sure you don't end up with the same problem in a year or so.
Jun 12, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Refrigerators Logo
260 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
