Question about Ovens
Cannot set up the timer controls for my oven model EL716 It has 5 control buttons & the bottom oven keeps going offcan I have full instructions please. i have lost the manufacturers handbook
  • 3 Answers
Turn off button not working
Posted on Jul 11, 2010
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
How do you clear Clock/Timer on a 1-year-old Viking Electric oven (Model # VESO1302SS)?
PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m3500217_F20669.pdf
Viking RangeClocks and Timers ... the potential risk of fire, electric shock, personal injury or damage to the appliance as a result ... NEVER use aluminum foil to cover oven racks or oven bottom. ... Keep area around appliance clear and free from combustible materials, .... 1. Push and hold the "MIN/SEC TIMER" and "BAKE TIME" buttons.
Nov 26, 2015 | Viking Ovens
Turned oven to bake it keeps beeping with message "door"
Oven keeps beeping:
How to Get GE Oven to Stop Beeping eHow
Apr 21, 2014 | Whirlpool Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
MY KENMORE GAS OVEN WILL NOT HEAT
If the control/timer/clock works
The problem is usually the igniter not reaching the correct amp draw.When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
If the control does not work try this link Replacing oven ERC
Oct 29, 2010 | Kenmore Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
267 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
