Question about RCA DRC8030N
Says hello its says hello the blue or purple display then goes out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
This is the power on procedure. Once it goes out, then press the poer button. If all you get is a blue screen, then turn off the progressive scan by pressing the small round button on the remote that is labeled "video out"
Posted on Jun 12, 2008
Intallation instructions for Fuel module for 2007 HHR
It would seem like purple to purple and blue to blue...just a guess.
Jul 15, 2014 | 2007 Chevrolet HHR Special Edition
Were does the blue green and purple wire go for itrp fm transmitter
Blue goes to A, Purple goes to G and Green goes to V! I need to know what the pinout is for the headphone jack side
Nov 21, 2011 | Griffin Technology iTrip Auto with...
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Wire diagram for DEH-P3700MP
usually is on the deck under the sheath on top or bottom.yellow is battery back-up this goes to power all the time to keep your clock and settings right,red is to power that goes off when ignition turned off,black is ground,blue is amplifier remote turn on,blue/white is power antenna,orange is dimmer that makes display go dull at night when u put headlights on.purple wires and green wires are rear speakers,white and grey wires are front.as for sides im not sure
Jan 04, 2010 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Yellow tint
Hello. Here's the visual key to remember about projectors--LCD panels show their colors like this: RED lcd panel displays cyan onscreen(baby blue); GREEN lcd displays purple; BLUE lcd displays yellow. ( You now know where the displayed dust is!) The problem is most likely a burned blue lcd or polarizer filter in front of the blue lcd panel. This occurs when the dust filter isn't cleaned regularly or properly and heat builds up--yes, enough to "cook" the lcd panel or actually cause a burn to develop on the polarizer. The polarizer is just like a lens in a pair of good sunglasses. It is a small, extremely thin, pane of glass with polarizer material glued onto one side. When burned, it causes a "shadow" effect--that enhances the display of that particular color--in this case, yellow.--Hope I was of assistance!---Rick
Dec 30, 2009 | Panasonic PT-AX200U Projector
I can't find the wiring diagram for a bd216?
red goes to a power source that activates when ignition is on,yellow goes to a permanant power source that doesnt shut off like cigarette lighter power,black is ground,if thers orange its a dimmer wire it makes display dull when headlights turn on,u dont need to hook it up it will just keep your display bright at night without it.blue wire goes to your amp if u have one signaling it to turn on,blue with white is for a power antenna if you dont got one dont worry about it.as for sides im not sure about this but white and grey wires are for the front and green and purple wires are for the rear
Oct 19, 2009 | Clarion BD-216 CD Player
The images displayed are purple. I sometimes solved the problem by adjusting the focus. Now it remains purple all othe time.
Hello...The problem you're describing is related to the green lcd and most likely the main board(green channel). If the focusing removes the purple(you have *that* much dust in the unit?) then it *is* dust. You should be able to focus on the dust particles twice--dust on the front of the lcd and dust stuck to the back of it. I'm gonna give you the color table so you know what to look for and what you're seeing. Red LCD=cyan(baby blue) onscreen; Green LCD=violet(purple) onscreen; Blue LCD=yellow onscreen
If you have a lot of dust(and the green lcd usually is the main culprit by the design of the lcd panels around a glass "cube" internally) you might try blowing some air into the unit when it's cool. However, the unit probably needs a good cleaning--remember to clean the dust filter! To properly clean the unit, a trained tech will have to perform the job. The lcd panels are DELICATE and precisely positioned for displaying a sharp image.
Sep 18, 2009 | Dukane ImagePro 8755A Multimedia Projector
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Jun 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
RCA DRC8030N Logo
259 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
