Question about Motorola Lands Phones
How do I send dtmf tones with motorola v170 - Motorola Lands Phones
My answer machine comes on when someone calls but it doesn't record the message. In the space where it previously said 1 or 2 for 1 or 2 messages, it says "A." How can I fix it to record the messge for my Motorola Phone/Answer Machine MD681?
Posted on Aug 24, 2009
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
MMY fax machine can receive faxes but i cant send any fax ?
If you machine has a telphone handset attached, see if you can make an outgoing telephone call. if it can then your machine has a dialling problem. Check to see if your dialling method is set to tone/DTMF. It may be on pulse and if in the uk it may cause the problem. If it is on tone/DTMF then it may not be sending any tones. These are usually generated on the modem chip. If this is the case then a new control board will be required. Before buying a new one it may be prudent to RAM CLEAR the board (a full reset). It you want to do that then repost telling us what make and model you have. Good luck
May 09, 2011 | HP Office Equipment & Supplies
I cannot delete voice messages after having heard them. The dialpad does not recognize the touch to keys. How do I reset?
I HAD THE SAME PROBLEM, THIS FIXED IT. I HAD TO TURN THE DTMF TONES ON.
Goal:
Enable or Disable Touch Tones (DTMF) for the LG Xenon (GR500) Fix:
LG Xenon (GR500) Keypad Layout
Enable or Disable DTMF tones
  1. From the standby screen, tap the menu icon.
  2. Tap the settings icon.
  3. Tap Call.
  4. Tap On or Off.
Feb 27, 2010 | LG Xenon GR500 Cell Phone
Is it possible to have the kx-t7730 work on DTMF? My operator says thats the only way I can access some added services
It will, but you may have it programmed to not send DTMF in SYSTEM programming. Since the 7730 is backward compatible to every KX-T system Panasonic made, you need to post a model number of they phone system to get instructions.
Are you in a rotary dial phone system area? There are 3 ways to program dialing, rotary, tone, and suppressed. The 3rd one will ONLY send pulse dial and inhibits the audio. It may be that you can press # and force DTMF. In the last 20 years or so, we have never had to worry about that as our phone companies no longer charge for "touch tone".
Carl
Dec 10, 2009 | Panasonic KX-T7730 Corded Phone
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
TTY
TTY is the system used for the Hearing Impaired so they can read instead of hear the phone.
DTMF (Dual Tone Multi Frequency) is used by the phone when you are calling a land telelphone line and asked to enter press numbers to get a response, such as a password or changing to a different language.
May 24, 2009 | Motorola Mobility KRZR K1 Cellular Phone
Use a GP300 to open a security gate? is it possible?
Hello hougies1,
Yes, what you describe is possible, although it may require some custom set up. You would need a receiver and circuit set up at the gate to receive the signal from the GP300 and activate gate control mechanism. You would also need some sort of signalling device (such as a DTMF touch tone pad).
There is an optional DTMF pad for the GP300 or you could use an external DTMF tone generator and just hold it up to the microphone of the GP300 to send the tones. Additionally there are several out of the box receiver solutions that include activation circuits that could be tied into your gate control. The Ritron TeleSwitch immediately comes to mind (Ritron has a whole line of gate control products) but other manufacturers such as Motorola have solutions available as well.
I'd recommend contacting your local professional two-way radio shop and explaining to them what it is you are trying to accomplish. I'm sure they could give you some guidance and pricing.
Best Regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Non-selections
Hello InHunter,
It looks like your DTMF tones has been disabled.
You would need to go to your Settings folder.
Go to "Initial Settings"
Scroll down to DTMF tones and ensure that it's set to "short"
Hope this helps,
cHiPz
Mar 21, 2008 | Motorola Mobility RAZR V3
V170 text problem
Did u try calling you're cellphone company to know if they blocked the text messages ? If you're text messages are not block, can you tell me more on what happens, what error/messages you get or simply what you do
Jun 16, 2007 | Motorola Mobility V170
Keypad not working during phone call
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
Oct 18, 2006 | Motorola Mobility RAZR V3
Lands Phones Logo
78 people viewed this question
Top Motorola Lands Phones Experts
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
