Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Spark plug wire will not stay on
Since I bought this machine the spark plug wire pops off all the time . I think I need a whole new spark plug wire. It is getting old having to put the wire back on the spark plug 10 to 15 times every time I cut the grass
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Just an idea is there a lot of vibration on the cutting head as this can cause the problem or you might just have to replace the HT lead for a slightly longer one.
Posted on Jul 26, 2010
Had sparks from coil, bought new coil same problem, bought new distributor, now car will not even start
By distributor, is that the cap or the whole piece of aluminum- housing with stator assembly/ control module/shaft/rotor/cap, the whole sha-bang.
If it was the "whole" distributor & If it ran before you put the distributor in & you only had sparks then the distributor was installed wrong.
Check for spark at the end of the plug wires. If you have spark then its more likely the distributor is in wrong &/or the firing order is off.
Sep 18, 2010 | 1987 Chevrolet Camaro
Had a noise like a lifter pulled the plug wire off the front cilinder and the noise was gone
Now, the question is "what happens if you put the wire back on"? If you have put the wire back on and the engine is running correctly, the only thing I can think of is that the wire wasn't on good to begin with. What you were hearing was the spark popping under the spark plug cap. I used to set the initial timing on an engine using the pop of the spark plug. Simply turn the ignition switch on with the spark plug out of the head but lying on it. Rotate the engine and watch for the timing mark on the crankshaft. Notice the position of the timing mark when you heard the spark plug "snap".
If the spark plugs you use has the screw on ends where the plug wire connects, make sure you keep these tight.
Good Luck
Steve
Aug 13, 2010 | Harley Davidson FXST - FXSTI Softail...
1974 350 cutlass motor has timing issue how do i install a distributor and get motor to top dead center if that is indeed what i need to do you get the timing back to stock timing setup
Your going to have coil wire, then pull out number 1 spark plug, then you have to have to have someone put there finger in the number 1 spark plug hole as you turn the motor over slowly in little increments till his finger pops out of the whole then you know you'll be at top dead center. Then your new distributor should go right in
May 22, 2010 | ACDelco Ignition Key Alarm Switch D1458C
Okay the car has new gasket and new wires and the spark plugs wires pops out of the valve cover why is that
If you bought after-market spark plug wires, that is not from a dealer, than sometimes the spark plug boot may be a tad short or loose on the spark plug and will slip or pop off. Take them back to the supplier in exchange for a better brand.
Mar 23, 2010 | 1992 Honda Accord
My 2005 lincoln Ls check engine light and wrench light comes on. the first time - a ford tech. changed a spark plug& wire. the second time a different spark plug & wire. third time another spark...
I have the same problem. My Lincoln Ls wrench light comes on and it quits. All spark plugs, all coils and the throttle body has been replaced. I think the LS model is a lemon! Any information or suggestions will be appreciated.
Thanks, Betty
Mar 12, 2010 | 2005 Lincoln LS
Car spits and pops like the points are bad in a 60s car.no power
Yes these optispark systems had all sorts of problems in wet weather most of the time you could replace the cap portion and that would solve it but most of the time I would replace the whole thing including new plug wires, coil wire,and spark plugs .Due to the fact that you have to remove water pump to access opti spark
Sep 01, 2009 | 1995 Chevrolet Camaro
Car Starts but dies
Give the car a "Tune-up". Replace the spark-plugs, the spark-plug wires, and make sure the "Timing" is correct...OK
Jan 04, 2009 | 1994 Ford Thunderbird
Rough idle new plugs shot in 20 mins
your head check for burnt or damaged valves. or spark control
Nov 21, 2008 | 1994 Pontiac Sunbird
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
166 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
