Question about Sanyo VWM-800 VHS VCR
Parental guardian controls
Will this work with watching tv also? if i leave the vcr on
  • Sanyo Master
  • 17,130 Answers
Yes a VCR can recorrd another program of your favourite channel while you are watching another. This is the reason why a tuner is incorporated into the VCR. You will need to tune the VCR tuner accordingly so that this function can be made use of . Also you can use the timer too record any TV program when you are out of house/station. I think that must have been what you had in mind? good day
Posted on Jul 15, 2010
How to reset password on tv guardian model 301
Press TVG button 5 times to reset device to factory defaults.
Alternatively, go to setup. Then Parental controls. Then scroll down to where you can enter a 4 digit code. To unlock and reset, enter 788444. Hit enter. This will unlock it. Next, enter in your 4 digit number.
Oct 25, 2014 | TVGuardian Tv guardian 101 - the foul...
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
How do you unlock patental controls on my tv
You should be able to find parental controls in the main dvd on screen menu
Aug 05, 2009 | Televison & Video
Parental lock
i have the same exact problem what i figured out is that i cant watch cable on it but when i hook a vcr to it i can watch movies. but when i hook my dvd player to it the block comes back on. so i hooked my playstation 2 to my vcr and hooked my vcr to the tv and i can watch dvd's that way. thats all i have sorry..
Oct 20, 2008 | JVC AV-27820 27" TV
Can't Reprogram the TV Guardian code
Forgotten Parental Control password can be bypassed/cleared by entering "788444" even if 4 digits "----" appears, then press ENT to clear the current password. You can then enter a new parental control password.
May 27, 2008 | Sanyo DWM-390 DVD Player
Tv guardian settings
OK I FOUND IT!!! IT'S 1234, when the parent control screen shows up press the play button then enter 1234 then press play again!!! The movie plays then!
May 08, 2008 | Disney Princess DVD Player
TVG Help
If the movie dosen't have close captioning the tv guardian will not work. For the tv guardian to work there has to be close captioning.
Feb 17, 2007 | Sanyo DVW-5000 DVD Player/VCR
Sanyo VWM-800 VHS VCR Logo
63 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
