Question about RTO Construction Bobcat by Woody Click
I have A bobcat 863 that just quit running during operation now the guages are on even with the key off and it does not start... If it does start it runs for about 30 seconds then shuts down. Any help out there dave
Can I find out what year a Bobcat is by the serial number?
look here
http://www.bobcat.com/company-info/help-center/faq
Apr 03, 2017 | The Optics
Have a 863 Bobcat and glow plug light is flashing will running
This is caused by burnt out glow plugs, have them all tested.
Dec 15, 2016 | Cars & Trucks
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
Bobcat 863 starts, runs but, wont move or raise?
What is bobcat863 a play name on a online game
Jan 28, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
I have an 863 bobcat that doesn't idle well and continues to quit running. I changed the fuel filter, put heat in tank and a little bit of diesel conditioner anti-gel.
There should be more than just one filter on that motor, check at the lift pump and injector pump.
Gelled fuel can be a pain, if that's the problem then warm it up (tarp and salamander for a few hours or leave it inside the shop overnight if the shop is warm), top off the fuel and give it a can of Power Service brand Diesel Kleen, then try it.
lp
Dec 30, 2010 | Bruder Cat Skid Steer Loader
I have a bobcat 863 it will try to start but wont turn over
makes a click but wont turn over check the starter aint locked up.
May 09, 2010 | Bruder Cat Skid Steer Loader
What do you have to remove to get to the fuel tank on 863 bobcat
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Jun 25, 2009 | Bruder Cat Skid Steer Loader
RTO Construction Bobcat by Woody Click Logo
63 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
