Question about Intel Motherboard
I suspect the motherboard's fuse has blown
Where is the fuse located on the motherboard
  • 808 Answers
Motherboard has no fuse so go to nearby repairing shop
Posted on Jul 26, 2010
  • 10,319 Answers
Some have them and some do not have fuses. If you are looking at yours and not one is found you must be looking at an Emachine brand motherboard for they never did installed one to save on cost
Posted on Jul 11, 2010
Relay and fuse identification 2007 ford fusion 3.0l
If you suspect you have a blown fuse, then you can find it in less than thirty seconds using my method. Instead of wasting time searching for the exact location, why not just remove each fuse 1 by 1, and keep putting them back (if good) as you go so you don't mix them up. If you have any blown fuses, you will find it! If you don't know the difference between a good vs blown fuse, ill post a picture to help you identify.
Dec 11, 2013 | 2007 Ford Fusion I4 SEL Sedan
Fuse diagram 1999 ford E150 van
Dec 10, 2013 | Cars & Trucks
Fuse for trunk
Dec 10, 2013 | 1998 Jaguar XJ8L
Fuse box ]
If you suspect you have a blown fuse somewhere,
Instead of wasting time searching for the exact location, why not just remove each fuse 1 by 1, and replacing them as you go so you don't mix them up. If you have any blown fuses, you will find it in under 30 seconds. If you don't know the difference between a good vs blown fuse, ill post a picture to help you identify.
Dec 08, 2013 | Toyota Pickup Cars & Trucks
What does each fuse goes to in each fuse box?
If you suspect a blown fuse, i suggest that:
If your car has the round clear fuses with metal caps on each end, then blown ones will be burned black.
Dec 08, 2013 | 1985 Ford Tempo
Motherboard GA H57 M USB3 (ver. 2) is not responding
Muhammad Shahid i will give link that may help you
manual
thanks
Apr 18, 2012 | Gigabyte GAH57MUSB3 Motherboard
2001 GMC Sierra headlights won't come on. Located 3 each 10Amp fuses that were blown and replaced them, however, headlights didn't come on.
what fuses were blown and replaced? Theres a TBC fuse under the hood, along with a Headlamp Relay. Theres a R HDLP and LT HDLP fuses, make sure they are getting power, and are good. If the LT HDLP and RT HDLP fuses are good AND getting power, then the TBC fuse and the relay is good. then I would suspect the Hi-Lo dimmer switch bad. The LOW beam ground wire is YELLOW, the high beam ground is PURPLE. see if high beams work, if they do, then I suspect the dimmer switch is bad.
Dec 17, 2010 | 2001 GMC Sierra Crew Cab
No Power
all sets must have rated fuse for protection. some units now use what is called a PICO-FUSE.this type of fuse is soldered into the pc board. usually marked with location i.d. F301,F901,F400. etc. these fuses look like resistors or in-line coils. check continuity w/ohm meter. if new fuse blows as soon as you plug in tv, suspect bridge diode ciruit or main filter cap(large ripple filter by main fuse. if new fuse blows when you try to turn on, suspect 130v regulator or high voltage short(horizontal-output, flyback transformer) good luck!
Feb 20, 2009 | Televison & Video
Intel Motherboard Logo
462 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
