I bought the samsung 250gb hard drive and it wont boot up
    President:
  • 2,712 Answers
Hello johnfogert,
1. First make sure that your motherboard supports a 250Gb hard disk.
2. Make sure that the drive is properly connected to the mother board and the jumper settings are set to Primary.
3. In the BIOS, ensure that the boot sequence is setup that CD is the first boot device.
4. Put in a boot XP CD. You must have at least XP installed, as any other OS older than this cannot support a 250Gb HDD.
5. Next ensure that you have formatted the drive during the install process. If you dont know how to install XP, get someone in the know to help you out.
This should work now...
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 19, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 23, 2008
    Has your issue been resolved?? If you have, please close
    this problem ticket with a Helpful or FixYa! rating. I would be very grateful
    for your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
    "Discover
    How to Achieve Your WILDEST DREAMS"...
    Free Download
    FREE SOFTWARE GIVEAWAY
    Windows Utilities
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk http://www.bootdisk.com/
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Boot device
your hard disk has upto 3 years warranty from the day of purchase
May 26, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
I HAVE A SEAGATE EXTERNAL DOES THE SAME THING
yes the PC will not boot when the external driver is connected, thats cause you dont have any boot files on the drive.
Jul 18, 2009 | Western Digital 250GB MyBook External USB...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
SumsungHDD Fails to load OS
Try:
Have you got a decent spinup?
Are the rest of the drives working properly, if they are not it may suggest faulty PSU.
Try connecting to a diffrent pc, or purchase a USB sata convertor
Aug 13, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Samsung 250GB HD250HJ SATA II.
Most likely if it makes sound then it is getting ready to crash, don't take a chance and remove your files and replace.
Jun 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
250GB harddisk only 130GB
try downloading any program that manages disks (partition magic for example ) and see if all the space appearsin that program, if so asign to that space a drive letter and format it .... (with the program that u will use )
Jan 16, 2008 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
