Question about Fisher and Paykel Washing Machines
Hello, I have a F&P Smartdrive 5.5 Excellence washing machine. Am I able to reduce the amount of rinses it does? It appears to be performing 2 rinses and I would like to cut it down to one only as we are on tank water. Many thanks, Lynne Whitford 11 July 2010
  • 2 more comments
  • kysor682 Jul 12, 2010
    Thank you very much, Luisa for such a helpful and prompt reply. Does this adjustment process alter it permanently or do I have to do this process for each wash? Many thanks and kind regards, Lynne 12 July 2010
  • kysor682 Jul 13, 2010
    Many thanks, Luisa - I will do what you have suggested. Much appreciated.
    Best wishes, Lynne
  • kysor682 Jul 29, 2010
    Hi Luisa
    I finally got around to trying out your instructions but I am not managing to do it successfully. My machine does not have the OPTION ADJUSTMENT MODE - it does have a button called OPTIONS which allows one to select "water saver/soak/timer". Is this the button you mean? If it is then I am still not achieving the desired result. I would appreciate your help again when you have a moment.
    Many thanks and kind regards, Lynne (30 July 2010)
  • kysor682 Jul 30, 2010
    That's ok, Luisa - I will come back to you later with the info you need. It's a bit of a mission to pull the washing machine out to look at the back for a serial number etc. Talk to you soon.....
    Many thanks and regards, Lynne.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now the 1st rinse cycle is always a spray rinse when the machine is set at the factory.If you follow these instructions then the 1st rinse will be a short spin only,with no water usage.1---Select the OPTION ADJUSTMENT MODE by pressing and holding the START/PAUSE button, then pressing the power button.Then release both after about 2 seconds. 2---Press either SPIN SPEED button to turn on the SLOW light,which is the spin only mode on the 1st rinse. 3---Once the SLOW button is lit push the POWER button to return the machine to normal mode again.Hope this helps and please reply back to let me know how you got on.We are on tank water too but thankfully we have a good bore.Looking forward to your reply and good luck.
Posted on Jul 11, 2010
  • luisa_sgro Jul 13, 2010
    Hi Lynne just read your second posting.Once you have set this rinse option it will continue until you put it back to the factory settings.Thank you for replying back and the lovely words.If you need help in the future do not hesitate to reply.Bye for now and good luck.
  • luisa_sgro Jul 30, 2010
    Hi Lynne, just read your last posting.Sorry I gave you the incorrect information.I must have the wrong model.Ok, I need the model number which is located on a sticker at the top of the machine to the back left.Also has you machine got an LCD screen?Please reply with additional information and once again sorry for the confusion.Hopefully I will get it right next time.Looking forward to your reply.
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
Fisher & Paykel washing machine excellence 6.5 smartdrive 8
see this possible causes: God bless you
see the diagrams
Lid switch
test for defective or open
Motor coupler
replace coupler motor for defective
Belts
worn belt
Clutch
wears replacement
Drive motor
one winding burn , run with one winding in one direction and another with the other winding.
Drive pulleys
frozen pulley, worn.
Transmission
broken gear+ shifter defective
Agitator
worn agitator replace
5_16_2012_7_59_29_pm.gif5_16_2012_7_59_43_pm.gif5_16_2012_7_59_54_pm.gif5_16_2012_8_00_26_pm.gif
May 16, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel smartdrive excellence 7.5
The pump has a thermal cut out fitted,
Pump must have over heated and cut power to machine.
Replace the pump to fix this problem.
Feb 04, 2012 | Fisher Washing Machines
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
My LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Jun 30, 2010 | LG Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
F & P Smartdrive Excellence works fine until it reaches the rinse and then just makes whirring noise. I can't get it to spin either and it won't empty. Is there a way of at least draining it. Cheers...
Hi Kiri,
F&P mahcines are a little hard to drain as the drain hose comes out of the rear of the cabinet half way up.
You may have to use a small container and manually bucket it out.
The drain pump is more than likely blocked (seen this a lot on the F&P) and is accessable from the front panel or underneath the machine.
Repost if you need anymoe help!
Jun 17, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
102 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
