Question about Mitsubishi WS-65711 65" Rear Projection Television
Hello we have a bigscreen model# WS65511 and we recently had a power outage not caused by lighting but when the power came on about 12hrs later the tv was blinking a green light we tried to reset it but we can not turn the tv on of the green light wont go off?
  • 505 Answers
Http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Posted on Jul 11, 2010
Model WOC54E whirlpool microwave/oven combo. recent power outage. microwave works fine. oven display says feature not available for baking when bake button pushed
Hello Carla Christian,
The problem with "power outages" isn't the
out part... it is the VOLTAGE VARIANTS...
Will cause a weak spot to fail... Poor sold joint
or
a transformer... but since you have PARTIAL
functionality you need to look to the specific
are of function that is DEFECTIVE...
I tried you part number but my
parts house wants more numbers...
Take a loo at what I found...
This site also has technical support... AND
VIDEO guides...
They can help you get your WHOLE model number.
http://www.appliancepartspros.com/whirlpool-wide-interface-board-wpw10412514-ap6021091.html
Carnac the Magnificent
May 31, 2017 | Whirlpool Ovens
How do I reset the control panel? Other ideas?
Hello. If your unit is running continuously, the timer/control board is defective and needs to be replaced. I need the make/model number to help you accurately. If you have the mechanical timer(round knob that turns), it's not advancing(no repair possible). If the unit has an electronic control, the program quite possibly is corrupted--or a relay is stuck causing the problem. Have you had a power outage recently--3-4 weeks ago? These are notorious for damaging the control boards from the current surge when power is restored. I hope I helped you--definitely give me the model number, thanks!
Oct 17, 2015 | Dishwashers
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
Have Eiki LC-X1000 projector. Recently had a power outage and since then it has not come back on. Have tried the reset, 230 AC ok and 300 DC volt ok, No standby light, nothing,then what can i do
dried out smd capacitors in primary part of power supply , common problem with this and similar models. 1uf, 2.2 uF and 1 radial 220 uF
replace bij 105 oC type
Apr 05, 2012 | Eiki LC-XG250 LCD Projector
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Hello!WE had recent power outage ,now door opener won't work.unit has power lights come on when remote pad pressed,but nodoor action?thank you
Along with the power outage you probably also had a power surge. You need to pull the logic board and check the printed circuit board for burnt or missing traces. Unplug the unit first.
Sep 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Power in house was shut off today, when restored, the timer led light by the power switch has been blinking constantly and the power to the TV will not come on...
Thats a common issue for that model which is caused by weak DM capacitors. When the power is down the caps discharge then they cannot recharge when power is restored and the led blinks non stop. Thw WS48511 - WS65511 DM repair kit from www.tvrepairworld.com has the caps and the repair instructions which usually solve that issue.
Aug 04, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
Mitsubishi WS-65711 65" Rear Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
