Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool calypso washing machine, model # GVW9959KQ2. I replaced the lid switch. Problem I have been having is the machine starts to run through its cycle(doesn't matter which cycle), then it starts all over again. It won't fully run through the cycle and finish. For 5 minuts on a cycle, it could take an hour to complete. I don't know what to try.
    Brigadier General:
  • 3,917 Answers
Hi
If the cycle doesn't advance it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Also check whether something is clogging the pump. Remove as much of the water from the tub as possible. Then remove the front of the washer. On the right at the bottom you should see the pump. Remove the black hose that goes from the pump to the tub (be ready for water). Check to see if something is clogging the pump and if so remove the obstruction.
Check to see if the pin on the lid switch is not broken or that nothing is keeping it from pushing the switch down. Or try placing something heavy on the lid where the pin and switch meet.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 11, 2010
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Where can I get a User/Owners Manual for Whirlpool Washer, Calypso Model # GVW9959KQ2
My buddy Robert and me got into a couple of these washers; an older one and a newer one. I took some photos and included your manual HERE and HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I HAVE A L 5 ERROR CODE ON MY WASHER AND IT WILL NOT WORK WE HAD THE WATER PUMP REPLACED BUT IT STILL HAVE THE SAME MESSAGE ITS A CALYPSO WHIRLPOOL
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
MY WHIRLPOOL WASHER WILL NOT WORK STATUS WASH CODE LS
lid switch error,thecontrolshould flash this error code if it cannot detect the lid switch opening and closing properly.this error code may also be used if there is a disagreement between the motor and machine controllers on the stat of the lid switch.the control should not allow the unit to run in this condition.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Mod: GVW9959KQ2, stops and shows "ob" as code for fast final spin. Also making high pitched whine during wash cycle. Appl svce place has suggested bearing or xmission. Any possible...
Sorry to say but they are right. The Calypso washer was a horible design given to whirlpool from maytag. I would suggest you go buy new machine. Buy someting that looks simple and easy to use. The more complicated the unit the more problems you will have down the road.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washing machine has no power!
This is the worst washing machine ever..the caylso by whirlpool,,, I want in on an lawsuit.../
Aug 10, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
77 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
