Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Kitchen Aid Superba Add dish Rinse Cycle green lights blinking constantly
bestdarngood
  • 3037 Answers
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
Posted on Jun 02, 2008
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
larryyb
  • 291 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
FixinFax
  • 3085 Answers
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Posted on Jun 28, 2009
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
Ice Maker not working in Kitchen Aid Superba. Light is blinking constantly on right side wall of freezer. Is this normal?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
44
Sep 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Miele Novotronic G842SC Plus
Add the requested rinse aid.. The light is on telling you it's low/empty.
Oct 20, 2008 | Miele 23 in. Novotronic G841 Built-In...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
76 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
