Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Clean coil light comes on - requre detail
Amana side-by-side refrigirator - clean coil light comes on - require detail explanation of what to do
    Guru:
  • 1,524 Answers
Remove the front grille, vaccum the coil or brush with coil brush.
Posted on Jul 11, 2010
I have an amana ptac model pth153B50AM it does not seem to cool much at all but I do hear the compressor come on.Before i cost myself a couple thousand dollars can anyone tell me is this fixable?
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
Jul 30, 2014 | Amana PTH153B50AM Air Conditioner
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
My hitachi refrigirator motor never stop running even i set the thermostat to number 2 only.
Try turning the thermostat to 0. If it stops it may not be faulty. Make sure the condenser is clean and clear.
Apr 25, 2012 | Amana Refrigerators
Clean coil light is on
The coil they are referring to is the condenser coil, which will be located underneath, and can be accessed either by removing the toe plate in front, or by pulling the cabinet from the wall, removing the machine compartment cover by removing the screws. In both cases its best to use an appliance brush or lint brush available at any hardware store, these brushes are about 2' in length, and contain black plastic bristles, and of course, unplug your refrigerator before doing any maintenance. Remove the dust and pet hair from the condenser with the brush, then vacuum the brush clean and repeat.
Jun 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have a side-by-side Samsung refrigirator RS24FAMS. There is bad smell coming from the back of it. I took off the panel at the lower back but found nothing suspicious. The smell is not from inside the...
there is a drain pan over there next to the compressor ...the old water get there and dry out ...see with flash light all over you might need to clean it (turn unit off) and do it gently ...good luck use some cleaning spray...
Jan 03, 2010 | Samsung RS2630SH Side by Side Refrigerator
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
I have a 10year old Amana 25cu SRV26V side by side and our freezer and food area is not very cold. The freezer side is only 20 degrees. Both sides have been turned up to 7 as high as it can go since...
Hi: It's a sealed system so if you need a recharge it will be expensive. You mentioned that the "air filter" in the back was clean. Do you mean the panel at the bottom of the back of the refrigerator? The coils are on the bottom (parallel to the floor across the bottom) and have to be clean. If you haven't done this; remove the grill and vacuum the coils. It's best to use a coil brush to get to the very back. A refrigerator coil brush is available at Lowes or Home Depot. I use an air compressor to blow them out. Then I have to dust the house. If the coils haven't been cleaned this will cause what you described. I hope this helps, Jeff
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Lg refrigerator side by side both sides are warm
Have you cleaned out the dirt from the bottom coils lately?? they need to be cleaned at least 1 times a year. use aq shop vac and a long brush and clean them.
Jan 21, 2009 | Refrigerators
Amana DRB2101Aw1
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
yhffg
Aug 06, 2008 | Amana AFD2535DES French Door Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
99 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
