Question about Refrigerators
I have the top refrig with bottom freezer..i opened the freezer last nite to find snow like ( not ice) ( i can scrape the snow and make snowballs) on all my food in both baskets. My ref and freezer are on number 3
    Guru:
  • 1,524 Answers
Snow is an indication of air leak caused by gasket not sealing properly.
Posted on Jul 11, 2010
How do I defrost my 10.0 cu. ft. top freezer igloo refrigator
you have to defrost the freezer the old fashion way...which means it does not do it on its own....you have to shut down the refrigerator in order for it to start melting...and then sop up any water with towels or bowls....key is to never let it get full of snow, so it's easier to do.....another way to defrost it, which I do...is to take a wooden spoon, never metal....and just scrape out the layers of snow that has formed into a bowl as you scrape, put the bowl inside and just scrape it into it.......if you do that once a month, it should keep the snow from too much buildup....I love my IGLOO it's perfect for just me and my condo....and I just redid my kitchen.....however after 2 years now, it's not cooling too well, which I have read other comments that this happens...
Oct 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
I have the refrig where the freezer is on the bottom, the bottom is working fine but the top is not getting cool.
a common problem with bottom mount freezers is the door gets left open,open the freezer door and look at the ceiling,is there ice on it and is there also frozen water droplets on the packages,if so the door was left open,you can shut the fridge down or unplug it,remove the food from the freezer,get a hair dryer and blow the hot air onto the back inside wall of the freezer mostly blow it into the open slots in the back wall,it will melt the ice that's in the air ducts,you'll see water dripping down,when it stops you can start the fridge and stick your hand in the top middle of the fridge section to feel if cold air is blowing in,all that it does is there's a fan in the freezer,all it does is blow the cold air from the freezer into the fridge section,if the door was open the warm air gets in and mixes with the cold air and it freezes up the air ducts and blocking them.if this isn't the problem open the freezer door,you should hear the fan blowing,if not you could have a bad fan motor,also put your hand on the back inside wall of the freezer,if there's like frost or snow on the back wall you have a defrost problem,a bad defrost heater,defrost thermostat or timer or board depending what the model is,but most of the time the problem is behind the freezer inside wall,or depending on your model there could be a damper in the fridge section,if it's stuck closed then the cold air won't blow into the fridge section.so first open the freezer door,listen for the fan,if it's blowing,check for frozen water droplets and ice up on the ceiling near the light and on the food packages,if you see this the door was left open,if the fan isn't blowing most likely it could be bad,then check the back inside wall for frost or snow on it,if there's frost on the back wall you have a defrost problem,most likely it will be a bad defrost thermostat or heater,you'll need to check them with a maeter,hope this helps,next time send the model number so i can look up your machine.
Sep 04, 2011 | Maytag Refrigerators
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
We have an 18-year old maytag side-by-side refrigerator. The freezer works but the refrigerator is no longer cooling. This occured yesterday. Over about the last three weeks there was some build up of ice...
Hello, usually means the defrost timer isn't working often enough....there is a small hole that is open between the freezer side and fridge side that will clog with ice ....you need to defrost this hole....its at the bottom of the freezer just inside the door....try this first but you may need a new timer also.
Thanks
Jul 13, 2010 | Maytag MSD2756G Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE S/S GSS25JETA BB freezing up on back wall of freezer & all cooling stops. It happened 2 months ago, then somehow starting working again after I scraped ice off back wall. Froze up again this week....
This is a little work , but it will save you a service call , parts up-pricing , and labor .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board ( you already know , since you changed it ) . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and when to cycle off .
Dec 14, 2009 | General Electric GSS25JET Side by Side...
Freezer problems
this particular refrig has only one temperature control which as you know is loated in the refrig section. but temperature isnt your problem. when the icemaker fill tube freezes up like yours has it is generally a sign of a bad icemaker fill valve. the valve seals will go bad and allow water seepage into the line, this seepage will freeze creating a snowball effect freezing the tube. you can use a hair dryer to remove the ice from the tube, and either replace the fill vlave yourself or have it replaced
btw the fill valve is the part that the other end of the fill tube is connected to on the back/bottom of the refrig in the compressor compartment. Good luck and message me back if you have any questions. Thanks Peyton
Feb 24, 2009 | Hotpoint HTS17BCM Top Freezer Refrigerator
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No cooling in refrig, botton freezer forming too much ice
let me know I can help you get it going again..
Sep 01, 2008 | Amana Refrigerators
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Refrigerators Logo
317 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
