Question about Magic Chef Microwave Ovens
Magic chef model VM11DN-8P When we set time for
Magic chef model VM11DN-8P When we set time for three minutes it will run for about two and a half minutes and stp working but timer will stay on. If you wait a couple minutes it will run again.
MicrowaveSvc
  • 9098 Answers
SOURCE: Magic Chef Microwave looses power when making popcorn
That does indeed sound like the mag is overheating and the thermostat is tripping, but it's probably not the steam.
Do you feel a good amount of air flowing through the vents?
If the cooling fan is not running or the air vents are blocked, that wil allow the magnetron to overheat.
If air flow is not a problem, then you may have a defective magnetron.
Assuming it's still under warranty, it would be best to let a Magic Chef-authorized servicer handle it.
For more help from Magic Chef / Ewave : http://www.mcappliance.com/ ; Contact page http://www.mcappliance.com/contactus/contactus.asp ; Order
parts https://www.mcappliance.com/orderpart
Posted on Oct 22, 2007
problem solved
Posted on Jul 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Posted on Nov 27, 2008
  • 686 Answers
SOURCE: Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Posted on Apr 12, 2009
bestdarngood
  • 3037 Answers
SOURCE: Magic Chef microwave oven (8 years old) heats only
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 12, 2009
Magic Chef microwave model#mco165ub cant seem to turn up the power level. when I hit the power level button it cycles through -20, 0 and +20 but nothing happens when I hit enter.
Try unplugging the unit for a few minutes. The microprocessor on the control panel may have locked up. Leave it unplugged for at least 15 minutes to see if it will reset.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 16, 2016 | Magic Chef Microwave Ovens
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
Jan 23, 2012 | Magic Chef Microwave Ovens
Magic Chef VM11EB-8P micowave oven act like nothing is wrong ,but will not heat .make all regular noises like it is working
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 27, 2010 | Microwave Ovens
I am unable to set my clock on the Magic Chef MCM1110 W/B Microwave Oven I just purchased following the Instruction Manual
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Aug 17, 2010 | Magic Chef MCD1110ST Microwave Oven
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
Aug 14, 2009 | Magic Chef CMV1000B Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
