Question about Dewalt & 14.4V Heavy Duty Xrp Drill/Driver Kit
The chuck on my drill is hard to open and close around a drill bit. Is there a way to losen the chuck up a little?
    Habit-Forming:
  • 57 Answers
You can apply som light lubricant spray to the threads or to the inside of the chuck and see if that helps. If not it may be permanently damaged or corroded and you may need to replace it.
To replace get you replacement chuck first, then;
Open the chuck fully. Inside the center bottom of the chuck you will normally find a reverse threaded lock screw that you must first remove. If it is hard to loosen, you may need to heat it with a micro torch or a heat gun to make the thread lock compound slip. Then fasten the smaller end of an allen key firmly into the jaws of the chuck. Engage the low gear. Then hit the longer end rapidly with a hammer to unscrew the chuck by rotating it anti clockwise.
Posted on Dec 03, 2010
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
Milwaukee1/2 magnum hammer drill keyless chuck stuck closed
yes call 1-800-sawdust that's the Milwaukee factory number. They can tell you what the spindle and thread sizes are so you can order a keyed chuck. They should even be able to tell you what chuck they have that will fit it.
Jan 12, 2013 | Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
Black & Decker Cordless drill 9.6V Model PS3350
Sounds like something may be binding. Try applying some very light (sewing machine) oil to the chuck and other parts, and working it in. Perhaps, over time, it will loosen up.
Sep 14, 2017 | Tools & Hardware - Others
I can't get the teeth to close around the bit? It is stuck open any solutions?
Some chucks have a screw in side the chuck maybe a star-head it could be lose.
Feb 05, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do I get the opening on the drill to close around the drill bit
Turn the "chuck" (the round part that the drill bit goes into) with your hand until it is snug, then use the chuck key to tighten it the rest of the way. The chuck key should be strapped to the cord of the drill. It looks like a gear and has a "T" handle for turning it. It fits into the gear teeth on the chuck.
Dec 01, 2010 | Garden
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
There is a little metal plate that is sticking out at the back of the chuck and opening and closing of the chuck has become very hard. I cannot find a schematic for this drill. I took the screw chuck off...
Place tool lightly in vice, place any allen wrench , L shaped type , with long end out of chuck, small end in chuck. clamp chuck jaws tight around end of wrench. With pipe or hammer, tap end of wrench counter clock wise.
These chucks are tight.
Jul 08, 2009 | Panasonic 15.6v Ni-mh Cordless Drill -...
Dewalt & 14.4V Heavy Duty Xrp Drill/Driver Kit  Logo
167 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
