Question about Philips SA1928 MP3 Player
Battery icon has a lightening bolt in it. Just charging it for the first time.
  • Philips Master
  • 17,130 Answers
When you are charging the set the icon that represents is the ligtening bolt. since you are charging for the first time. so so for 12-15 hours, then use it to drain completely and recharge. do this three times. The your battery will come back to optimum condition. It is good if you can do this once every week to discharge and recharge which will enhance your battery life. do not try to charge mid way all the time but try to schedule your charging cycle. Helpful? good day
Posted on Jul 11, 2010
My 2013 kindle fire HD 7 3rd generation screen is black and there is no reset hole.
Not many buttons to control it but you might hold down the on button for a long time while the charger is connected.
Nov 27, 2015 | Tablets & eReaders
My iphone is pluged up and it is supposed to have a lightning bolt beside the battery life and it doesn't . It is almost dead and this phone is brand new. What do I do?
When charging the lightening bolt should be shown in the middle of the battery symbol! Are you using an original Apple charging cable and is it a USB mains or computer charger?
Dec 26, 2014 | Cell Phones
My CyberPad iview's battery is completely dead. How do I recharge it? Blue light is not lit when it's plugged in and there is no lightening bolt appearing.
Is the charger ok?(silly me). Unless the battery is functionally dead, it should work. Sometime plugging into another wall outlet may help.
Jan 16, 2014 | Iview Cyberpad 900TPC 9-Inch Tablet
I cannot open my laptop with control-alt-del. when I power on the laptop, I get a continuous high pitched alarm. also, the battery charge (lightening bolt icon) does not stay lit. Is it power adapter or...
It could be either or both. First, use a multimeter to check the power output from your adapter to see if it is within specification (your particular computer requires 19 VDC). If the voltage is low, you need a new adapter at least. The battery charge icon not staying lit can be because of a bad adapter, but also can be because of a damaged connection in the plug where the adapter jack plugs in. If you wiggle the plug, does the icon go on and off?
If you remove the battery from the computer and leave the adapter plugged in, does it make a difference?
Only more rarely is it the battery itself. Try the above first.
Dec 29, 2010 | Dell Latitude E6400 ATG PC Notebook
Lightening bolt over plug icon
This indicates that your laptop is plugged in and charging the battery.
Feb 26, 2010 | Dell Inspiron 1501 Notebook
Is the lightening bolt supposed to flash orange? The battery will not keep a charge at all, so I have to keep it plugged in all the time. Does the orange flash mean I may be in danger of losing files, etc....
The orange flashing lightening bolt is confirmation the battery does not charge. It is not an indicator of any other hardware failure.
You can remove the battery if you find the flash annoying. The laptop will be lighter without the battery too!
Sep 21, 2009 | Dell Inspiron E1705 Notebook
I am having the same problem
The bios can only be flashed if you have more than 10% battery charge. check if you have any other AC adapter. is the battery does not charge with another adapter then it could be a battery or motherboard fault. Try another good known battery, If even a good known battery fails to charge then its a motherboard issue. Call technical support and get the motherboard replaced.
Rate if useful.
Aug 10, 2009 | Dell Inspiron E1705 Notebook
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
H340 i river
Horizontal lightning blot = OK = the battery is already fully charged
Vertical lightning blot = enough power for charging not getting to player - your USB port may be less than 2.0, or may be malfunctioning for some reason - try a different uSB port first - if still the same result, go into the Device Manager and make sure there is not a yellow exclamation mark by the USB port.
Use the wall charger if it will no longer charge via USB.
-Tha Mp3 Doctor
Jun 13, 2008 | iRiver H340 MP3 Player
Philips SA1928  MP3 Player Logo
102 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
