Question about Microsoft Xbox 360 Console
No Video Everytime i plug in my xbox and turn it on i can hear just sound but i see no video. I switched televisions and got the same issue on each one, then i went and barrowed my friends av cord and still suffered the same problem, what can i do to fix it??
  • Microsoft Master
  • 13,433 Answers
If you are sure that you had the right input selected on the tv, then check if you still have warranty, repair might be required, contact your dealer.
Posted on Apr 19, 2008
Ok I have a xnox 360 and when i plug the color coded cables into the color coded tv inputs i turn the channal to video 2 and i hear sound but i could not see anything? sooo what do i do?
Are you using AV or component cables?
*Solution for AV Cable*
Check to make sure the cable is fully plugged into the port. Having it even just slightly out of the socket will render no video. If this doesn't work, try plugging it into a different port on your television to make sure the port isn't bad. If you still have no video - the video part of the cable could be bad and you might need a new cable.
Also make sure that if your cable has BOTH component and AV connections available that the switch at the end of the cable near the Xbox is set to "TV" as opposed to "HDTV"
*Solution for Component Cable*
Also check to make sure that all the video connections are fully plugged in. If even one of them isn't plugged in fully, it could render no video. Also make sure that you have them properly plugged in to the right color. If you're just quickly connecting it to the back of the TV without proper lighting, it can be easy to confuse the blue and green connections.
When using component, make sure that the switch at the end of the cable near the Xbox is set to "HDTV" as opposed to "TV".
Jul 09, 2010 | Microsoft Xbox 360 Console
My xbox power is on but the xbox wont switch on
It does nothing? No red lights or anything? Do you hear the xbox intro come on? If you hear the xbox but don't see make sure you have your video switch set right (HD for your HD tv's and SD [irc] for standard type tv's).
If this is not the issue. Try disconnecting and reseating the plugs and hard drive.
Hope this helps,
Bill
Aug 23, 2009 | Microsoft Xbox 360 Console
When we turn on the xbox 360 we hear noise but nothing on the tv screen. we checked all the cables and even switched cables with a 2nd xbox 360 system. nothing is different
Check the cables again and make sure your audio and video are not turned around. Also make sure the HDMI is not switched on on the input cable unless you have your 360 set to that on an HD TV already. If that doesn't work you might have an issue with your video input in which case you can purchase a new one online or in the store.
Jun 18, 2009 | Microsoft Xbox 360 Console
Lose sound on phillips hdtv unless xbox360 is turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 06, 2009 | Philips 42PFL7422D 42 in. LCD TV
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
360
You could try switching the cables from HD to Reg. Other then that it might be a Video short in the Television.
Apr 06, 2008 | Microsoft Xbox 360 Console
We cant see the video only the sound is perfect
are you using a hd television?
-if so, then replug in your plugs into the television, and make sure that the av cable to the xbox360 console end, is switched to hd.
-if not, then recheck your plugs, check that the av cables to the xbox360 console is switched to tv.
and if this still does not all work, then, its mainly where you plugged in the video cables into the television. so my main advance to you is to recheck where you plugged the video cables.
Jan 26, 2008 | Microsoft Xbox 360 Console
Cannot view picture or game for my xbox 360
Make sure you are using the correct video settings. Try using the basic red white yellow cords and see if that helps. Also make sure you have switched between HD and regular video. there is a switch on the video cable connector that plugs into the xbox.
Jan 06, 2008 | Microsoft Xbox 360 Console
Emerson LCD HDTV 19 inch won't connect to Xbox 360
Im not an expert on the 360s, but I believe there is a switch or option on them to play them in HD feed. They must be set to play HD as far as I understand.
Dec 26, 2007 | Televison & Video
Microsoft Xbox 360 Console Logo
13 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
