What should I do if there is no audio output from the speaker
    Genius:
  • 1,074 Answers
Check your speaker if it is good you can do this by putting a meter to the two connectors on the speaker.or using a battery with wires and connect them to the speaker which will give you a audible sound if that is absent then your speaker is bad..if there is sound then check the ic or transistor in your audio section.the speaker wire is connected to the audio section.
Posted on Jul 11, 2010
Picture ok sound through head phones only
Check the speaker/s. If the audio output by headphone is OK, and there is no audio output by the speaker; either the speaker or the audio output stage circuit will have the fault. Contact any service technician.
Gopakumar Gopalan Google
Mar 09, 2014 | Bush Televison & Video
3250hd
How have you connected the audio cables to the TV? The 3250HD has component, DVI, and composite video out. There is also two analog audio outputs (for the component and composite video) and a digital audio output. Make sure that you are using a TV and not a monitor. Many monitors do not have built-in speakers. (In that case, use external speakers.)
If you use the digital audio output, make sure that your audio receiver audio input is connected to the set top box audio out. Then make sure to set the correct source for that audio signal. (Note the TV may have a digital audio port; that is an audio out.)
If you are using one of the analog audio outputs directly to the TV, make sure that you are using the correct set of audio IN on the TV and audio out on the set top box. (If you are on the Component input, your audio won't be heard if you are using the Composite audio output.)
Next try different audio cables. Make sure that the TV speakers are on. (Some TVs have an option to disable the speakers if you use external speakers at times.) Try connecting the audio output to a receiver and speaker system (or speakers with aux in). You might need an RCA F/F to 3.5 mm M adapter for some devices. If another set of speakers do not work, then the set-top box probably has a broken audio output. If another set of speakers work, then the problem is with the TV audio. This could be a problem with the jack or the speakers.
I hope this helps.
May 02, 2013 | Black Box Computers & Internet
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
