Question about Mitsubishi WD-52725 52". Rear Projection HDTV
The tv screen has like a haze of a cloudy appearance. It looks like what your eyes feel like after being in a chlorinated pool all day. How do I fix that?
  • Mitsubishi Master
  • 8,457 Answers
Tv CRT tubes require coolant replacement.Tries websites like Tvrepairworld.com,Tvrepairkits,.com to buy the coolant kit to replaced it coolant on the CRT pictture tubes.
Posted on Jul 11, 2010
Ph level is at 'ideal' chlorine level is at 3.0 but the pool water is still cloudy. Please help?
The cloudiness could be suspended particles or algae. Use an algae k i l l er as recommended, then a flocculant (water clarifier) as recommended, then vacuum the pool bottom and run the filter overnight.
After that check the ph, alkali level, chlorine level, and adjust as needed. That should do it.
Feb 05, 2017 | Pool & Spa
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
My water looks a little cloudy. how do i clear it up. and are you supposed to shock your pool once in a while.
My wife takes care of our pool chemicals. When it gets cloudy, just hit it with a normal dose of chlorine. A normal dose is what you would put in in a given day. Run the filter for 24 continuous hours if necessary.
Gary
Aug 09, 2011 | Intex Krystal Clear Model 635 Pool Filter...
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
After 5 days using saltwater system water is cloudy. Before installing new system no cloudy water. Help.
Intex salt water system does not keep your pool cleaner. It is only a means to not have to buy liquid or tablets
If your salt is not at 3000ppm not below 2700 not above 3800 you will not generate enough sanitizer ( chlorine )
You need a good stabilizer to help hold chlorine content and a good non foaming algecide which you would use every 5-7 days
Don't forget chlorine consumption is caused by many factors.
# of swimmers, heat, sun, rain, did any one sneak in with sun tan oils and so on and the worst thing for a pool is to not use it on a daily basis.
Get your money back on the salt system and go with what worked for you.
Jun 25, 2010 | Intex Automatic Salt Water System for ...
High chlorine/cloudy/salt water pool
Purchase a PoolRx unit for your pool. PoolRx.com....No more algae!! Clearer water
Aug 26, 2009 | Pool & Spa
CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Aug 13, 2009 | Intex Automatic Salt Water System for ...
My chlorine generater appears to be working fine but the test strips show no chlorine in the pool. I have an 18 x 48 Easy Set and added 135 lbs of salt and ran the filter for 4 hours. This is the first it...
no chemicals needed -Test strip are not as accurate as liquid kits buy one for about 10 dollars
Also since it is a new set up you shouls run the chlorine generator for at least 8 hours.
Make sure your chlorine light comes on ( about 5 minutes sometimes a little longer after you set the timer)
Also get a test kit to detect salt 10 dollars for 10 tests Keep it as close to 3000ppm as you can the higher you go past this amount the saltier the water can taste
do not go below 2500 you do not want to have to be bothered adding salt for splash out or rain.
starting at 3000ppm gives you a long time before needing to add for the splash out or rain with these factors you only loose about 25-35ppm's when refilling and so on so it is a long way to 2500
One other pointer is to make sure you filter your pool enough. It is recommended to turn your pool water over at least 3 times a day
as an example I will use my 7000gallon pool with my 2000gl pump thats about 10 hours a day just for filtering. This does not include how long you need to leave the generator on to produce the amount of chlorine to produce a 1.0 or a 1.5 setting Also keep in mind that chlorine affects the ph so chlorine needs sel first before you worry about ph so once both are set then watch as the chlorine drops so will ph but once you run the generator to rebuild the chlorine level the ph will come up by itself. Ph will cause more problems with eye irritation and cloudy water than chlorine
Jul 12, 2009 | Intex Automatic Salt Water System for ...
Water is cloudy in easy set pool. How do I clear
not enough info like what kind of chlorine and if salt water set up Cloudy water is usually not enough filtering or low chlorine for an extended period of time Be more specific.
No matter what method salt or regular water you need to turn the pool water over at least 3 times a day/night
Lets use generic #'s if you have a 4000gl pool and a 2000gph pump you need to filter at least 6 hours you will need to adjust the #'s for you and figure out how long to filter.
It is also important to keep the chlorine between 1.0 and 1.5 then set your ph level with either ph up or ph down depending on what yours registers at after the chlorine is set.
Remeber that you must first set the chlorine since the ph is affected by chlorine level.
once both are set then the ph will go up and down with your chlorine so keep it in check after initial setting
for now add a little extra chlorine and filter for 24 hours then vaccum remeber to take out the filter cartridge once or twice a week and hose it hard with the garden hose. I am on my 3rd season with the same cartridge
Jul 11, 2009 | Intex Complete Easy Set Pool Kits 15' X...
NO CHLORINE
i just went through this
Are you using the instructions in the manual for locking the system after setting the number of hours?
If you are, they are not right
unlock the system, set your hours then press and hold the down arrow until it beeps and then press and hold the up arrow until it beeps, the system is now locked and in about 10 minutes the chlorine light will come on. Our pool went green and now that we have it running right the colour is changing before our eyes. Changed the filter and washed it out several times.
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
345 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
