Question about Vivitar ViviCam 8025 Digital Camera
Charging batteryif i dont have a device to charge the actual batt
If i dont have a device to charge the actual battery, can i charge it with this usb plug
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
Yes, assuming the USB port into which you plug it provides enough current. Not all computer USB ports put out enough current to charge other devices.
Posted on Jul 11, 2010
Toshiba a205-s5806 not charging batt bt powering mainboard
hmmm try these two options
first take out battery completely and see if puter runs on adapter
then put battery in and see if it runs on battery
if 1 works and 2 does not battery is ready for replacement(usually after 2 years)
May 24, 2012 | Toshiba Satellite A205-S5855 Notebook
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
2nd Gen IPOD nano dead batt.,not recogn.by computer or itunes
can you restore to factory settings?
it may need new battery...even if battery is dead it will still display apple sign but wont sync or charge.
Jul 31, 2009 | Apple iPod nano 2nd Generation MP3 Player
Never held charge more than a few seconds
you need a new battery This one is a dud
Jun 28, 2009 | Garmin nuvi 750 GPS Receiver
JVC GY-HD110U
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
Jun 18, 2009 | JVC GY-HD110U Camcorder
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Can i charge the batt for thec530 by pluging in the computer with the USB cord,Pc to c530
Yes, plugging the unit into the computer via the USB cord will charge the unit.
Dec 11, 2007 | Garmin StreetPilot c530 GPS Receiver
Vivitar ViviCam 8025 Digital Camera Logo
90 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
