Im trying to connect my yamaha psr295 keyboards usb to my music maker on my computer.but my keyboard didnt come with a disc so it wont load..i need help
AvioriX
  • 689 Answers
SOURCE: Keyboard problems
Hi
I like to inform you that multimedia keyboards has no lock or special connection other that USB or PS/2 connection. But special multimedia keys can be assigned by its software. Make sure if you have the CD came with the keyboard if you dont have it still chance exist that you can go to manufacturer's website and obtain the software utility
Good Luck
Posted on Dec 31, 2007
zitoglarf
SOURCE: My Laptop Pavilion dv4000 keyboard keys locked
Have you removed all power (AC adaptor and battery) for several minutes. Sometimes it may also help to hold the power button in for 10 seconds while all power is disconnected. Then plug back in and start computer.
  • 3 Answers
SOURCE: what cables for yamaha keyboard psr295 to connect with tascam 144
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Posted on Sep 10, 2008
  • 8 Answers
SOURCE: connecting a yamaha s90 synthesizer to usb computer
A little late for the original poster, but this answer may help someone else.
On the S90, press the "Utility" button then press the "F5" button under the display. Make sure MIDI IN/OUT is set to "USB" (using the DEC/NO and INC/YES buttons under the jog wheel). The factory default is "MIDI" which means no computer could detect it.
Once you've done this, install the S90 USB driver on the PC then plug in the USB cable. The PC should detect the S90 and you should get a new item in your windows control panel where you can set MIDI I/O and channels.
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Posted on Apr 27, 2009
How to connect Yamaha per 630 keyboard tot PC connection to Yamaha per 630 keyboard PC
Assuming it is a pSr630 keyboard then there are 2 ways to connect depending on the computer you are using. The 630 uses 5 pin din midi in and out.
1) If you wish to connect to USB then you will need a USB midi interface such as
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=11173
or
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=5894
2) If you are connecting to a desktop with a 15 pin socket you can use a cable
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18808
Your software then should recognise the input type in use and allow you to connect it accordingly.
Aug 09, 2015 | Yamaha Portable Keyboard
How can I transfer a 06PK61.bup file to a Yamaha YPT400 keyboard?
The BUP files are yamaha's proprietary back up file format.
Having the appropriate drivers installed, once you make the usb connection from computer to keyboard (yamaha), you should now be able to navigate the Yamaha's files as if it were a drive on your computer. I recommend placing the file in a directory with similar files.
Make a backup beforehand to avoid and problems.
Apr 04, 2011 | Yamaha YPT400 61 Key Portable Keyboard...
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
Connecting dgx 530 with computer
try using stereo cables (RCA)....thats what i used before i went to 1/4 cables after adding a studio mixer.
Dec 09, 2009 | Yamaha Full-Size Keyboard
Installation of driver usb yamaha to host
The best thinkg to do would be to use the Yamaha's support section on their website to find the latest driver pack for this keyboard.
Once you have downloaded this, just run the install file and this will load all the vital files you need on the computer.
Aug 31, 2009 | Yamaha Full-Size Keyboard
CAN'T CONECT TO MY PC...
Here's the website to download your USB drivers Good luck & have fun. If this helps you plz rate this 'fixya' for me. Thank you kindly.
http://www.yamaha.com/yamahavgn/CDA/ContentDetail/ModelSeriesDetail/0,,CNTID%25253D2382%252526CTID%25253D204600,00.html
Feb 01, 2009 | Yamaha Full-Size Keyboard
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
What cables for yamaha keyboard psr295 to connect with tascam 144
Aug 01, 2008 | Tascam US-144 Sound Card
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
