Question about Konami Dance Dance Revolution Hottest Party for Nintendo Wii
Song starts, then slams the doors .....stops and says we fail..... how do we fix?
It is because your + sign is stuck. Unplug your mattress and shake it as you would a carpet. It will fix your problem!
Posted on Aug 07, 2010
How to fix the back door electric for the Yukon Denali XL loks
Each door has a solenoid to unlock door under power, and this is usually what fails when lock fails to work under power. Link to lock from solenoid is also common problem and come out of plastic holder if door is slammed as plastic gets brittle, another common problem. I assume door locks manually. Rarely is it anything else, other than broken wire or connection to door at hinge boot.
Aug 16, 2014 | Cars & Trucks
Door will not close without slamming
Possible causes - door switch, or door switch assembly out of adjustment; plastic latch guides on door switches worn; door hinge worn, causing door to be out of alignment. If it's the last one, the unit needs to be checked for microwave radiation.
Dec 22, 2013 | Panasonic Inverter Countertop Microwave
My maytag nepotune high efficiency model MAH550BWW door does not close properly...have to slam the door several times before the latch closes to set and start the wash cycle
There is wear in the door latch/lock mechanism, It will eventually fail completely and you will have to replace the door lock
Mar 12, 2012 | Washing Machines
Unit shuts off slam door or hit unit and it comes
Replace the thermostat , and that will guarantee , to fix the problem . Where the temp is adjusted .
Dec 22, 2009 | Refrigerators
The washer turns on, fills with water, then stops. Agitation won't start unless you slam the lid or sometimes if you "nudge" the setting forward and then pull out and then in.
Sounds like door switch may be failing, or the wiring between door switch and timer has loose connection. You can replace the switch or check ther wiring, or bypass the door switch circuit by jumping the leads at the timer
Aug 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door switch problem top loader
I fixed mine with a toothpick and a piece tape. Make the tab on the door longer that activates the switch. Try triming the lid bumpers
Apr 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Creda W120VW Intermittently not starting when door is closed.
I don't know if you are still having a problem with your washer, but a new door lock is needed to put it right.
Sep 09, 2008 | Creda W120VW Front Load Washer
Microwave auto-starts when door is closed
You probably have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 03, 2007 | Sharp R-1200 Microwave Oven
Turntable continues to rotate.
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files via a Yahoo search. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see from time to time, and we repair those nationwide, but it's usually a door switch. If you still have a problem, please post again. Be safe!
Oct 29, 2006 | Panasonic NN-S264BF 1200 Watts Microwave...
Open Questions:
Konami Dance Dance Revolution Hottest Party for Nintendo Wii Logo
62 people viewed this question
Top Konami Video Game Consoles & Games Experts
Tom Chichester
Are you a Konami Video Game Console and Game Expert? Answer questions, earn points and help others
