Im watching my parents house, the A/C will not turn on. It keeps tripping the fuse in the box outside. is there a reason the AC would keep tripping the fuse? I live in Phoenix, it is hotter than hell. please help asap. The AC is about 3 years old at most.
  • Robert Dressler Jul 11, 2010
    how long after a reset should I expect for my AC to start blowing cold again? The breaker is no longer tripping. I hear the AC in the back yard going with the fan turning but no cold air in the house yet, still worried. It wasnt working before but now it is turning. could it still be the compressor if it is spinnning? and how long could it take to get cold again? thanks. fast response would be awesome. Arizona heat even at this time is horrible for my babies. thanks
  • Robert Dressler Jul 13, 2010
    thanks, was the compressor
    President:
  • 1,561 Answers
The problem could be too many appliances are being run on the same circuit. Unplug or relocate appliances that share the same circuit.
Time delay fuse or circuit breaker of the wrong capacity is being used. Replace with a time delay fuse or circuit breaker of the correct capacity (see "Electrical Requirements" in the Installation Instruction).
An extension cord is being used. Do not use an extension cord with your air conditioner.
Also check the AC outlet, to see if the connections are ok, because bad connection could cause this, try another AC outlet.
Take care.
Posted on Jul 11, 2010
  • 3 more comments
    guys the AC is outside and has been plugged into the same unit for years. it is somewhat a new AC outside. the fan is on. i cannot tell if anything else is working. its been on for an hour and still no cold air. its getting hotter. this is ***!
  • Sulaimon Jimoh Olayemi Jul 11, 2010
    If your A /C has been plug for an hour and yet you are not getting cold air, If the unit is working properly it should cool the home. Is your filter
    clean? Look and the evaporator in the inside unit. Is it frosted up? Do
    you have condensation water in the pan? Go to the outside unit and feel
    the air coming out of the fan. Is it warm? Now feel the 2 copper pipes
    coming out of the unit. Is the small one warm or hot? Is the larger one
    cool ? Is there moisture on it
    Freon does not loose it's ability to cool. There is either insufficient
    Freon for the size of the system indicating a leak, or the pump is
    wearing to the point where it can no longer provide sufficient
    compression of the gas. Also, you can use use air pressure pump to vacuum the surface and internal part of your A/c because the problem could be dust but quite sure the unit is low on freon and will need to be refill to perform excellently again.
    Take care.
    finally a intelligent answer. lemme check. ok the little hose is normal temperature. just kind of air temp. not cool at all. no condensation on the bigger hose. i cannot see in the AC unit. too dark and the flash light does not do a good job. I cannot see the condenser. It is the AC box (unit) and two hoses coming out of it and one surrounded by plastic (thinking may be the electrical wiring). I have a **** load of fans working now. keeping it barely bearable.
    oh and the air coming off the fan is warm-air temp which is about 90 degrees.
    Open up the closet, bring a flashlight and find the water pipes that are
    connected to it. They are usually small & copper. Feel them. Are
    they cold? Are the icy? Are they frozen? If yes, then move on.
    Turn off the A/C. Pull out your A/C filter. Is it dirty? If yes, keep
    going.Change filter. Then turn on the A/C "fan" switch from AUTO to ON. What
    has happened is the cold air that was being produced by the A/C until
    couldn't push the air through the vent because the filter was too dirty.
    Clogged. Thus creating a situation where the pipes that brought the
    cold water to the A/C got colder and colder until they froze.
    Read more: How
    to Fix an Air Conditioner That Is Blowing Hot Air | eHow.com
    http://www.ehow.com/how_4999716_air-cond...
  • 2,272 Answers
There are few possibilities that has to be checked. First thing is that you check connecting your Ac to any other power outlet.In many cases this will not be possible.No problem.If you have any other high voltage electric appliance like heater,microwave,washing machine,etc etc then connect that to that outlet and check.If it works properly then your electric line is ok.If the other appliance also shows that same problem then its the electric line problem. But if electric line checked out ok.Then its the problem of any of the ac component weak and due to that its getting overheated and this is tripping the fuse outside the house. Things to check in ac are 1 bad compressor.2 bad run capacitor.3 bad start relay and capacitor if it has one.4 bad breaker. 5 bad fan motor. In some units there is start up relay and in some there is start up capacitor.Its beside the compressor. Either the Air Conditioner compressor is bad, or the breaker is bad. Since breakers are a lot cheaper than compressors, you may want to replace that first. If the breaker is old, it is a good possibility. But if the breaker is new, it may be the compressor. Get the ac voltage checked by the meter if you are familiar with testing volts from meter in other case get this checked by the electrician. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    i appreciate the help. well. I would keep on resetting the breaker and it would trip right away. I got it to stay on and it seems as if the the ac unit outside is spinning (the big fan) but I dont feel any cool air or even much pressure coming out of the wall outlets (where air comes out, sorry don't know the name of them).
  • raj somaiya
    raj somaiya Jul 13, 2010
    Thanks for keeping updated.
Where is the fuse for a 9 year old Kelvinator undercounter oven situated?
There is none. Look in the circuit breaker box on the outside of the house for the one marked oven. It will be 2 breakers side by side with a metal part connecting both levers together. Move both handles back and forth a couple of times. That may restore power to the heating element. If one breaker trips it leaves 120 volts to work the light and the clock, but the element is 240 volts. It may have shorted with age. You may need to replace the elements if the breakers keep tripping after you reset it at the panel.
Jul 28, 2016 | Ovens
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
My AC keeps blowing fuses. Everything works, but I was told it was the AC control switch that needs replacing. Will I need to buy the whole panel ? The heater works fine, but the AC and defrost buttons...
Hi Gouldkareng.
Please allow me to try to help you.
There could be a number of reasons why your AC keeps blowing fuses. Some of these could be..
* An issue with your fuse box.
* The filter could be dirty.
* There could be a problem with your central power supply.
* The condenser fan might have gone bad.
* There could be low refrigerant.
* Your circuitry might be causing the problem.
* The capacitor could be malfunctioning.
The list is way too vast. You could find a whole list of problems detailed here...
https://getpureair.com/why-does-my-air-conditioner-keep-blowing-fuses/
As there are way too many problems wiuth fixing this kind of an issue, there are way too many solutions and if you want to try and fix the probelm ob your own, here is some information that could be usewful to you..
https://yourairexperts.com/blog/ac-tripping-breaker
You can also find more help here...
https://asm-air.com/airconditioning/air-conditioner-circuit-breaker-keeps-tripping-asm-tips/
I have also attached a video that you might find helpful in aiding you with this issue.
Though it is very true that fixing this kind of a problem does not involve rocket science, it might turn out to be too much of an ordeal for you. As you are in Houston Tx, at the following places..
https://acmanhouston.com/contact-us/
https://www.abacusplumbing.net/
https://www.besthvacairconditioning.com/
http://24.repair/
If you want to buy used ACs in Houston Tx, do check out the following...
1. A1 & AC Appliance Center Address: 1028 N Shepherd Dr, Houston, TX 77008, USA Phone: +1 713-868-7402
2. https://pmhvac.com/
3. http://www.jmapplianceac.com/
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | 2002 Buick Century
My amana ac unit over heats the circuit breaker and trips it off after running for about 15 minutes. It will not blow the fuses on the outside disconnect next to the unit outside.
What you described 'shouldn't' be happening - "if" the outside fuses and the inside breaker are sized correctly for your air conditioner.
I would make sure that the fuses in your outside disconnect were the proper size (for your AC), and that the inside breaker was of suffienct size to handle the air conditioner, and whatever else might be on the circuit.
Note: You would never want the 'outside fuse size' to be bigger than the inside breaker.
For example: 50 amp fuses in the outside disconnect and a 40 amp inside breaker is a no-no.
Often, for whatever reasons - someone will put larger fuses in the outside disconnect than what is called for.
When this happens the inside breaker is the only safety on the AC.
The problem is - for whatever reason - your inside breaker should not be tripping off.
It's likely that the AC may be on a inside breaker "that also has other things i.e. dryer, electric range or Refrigerator," and therefore any of these components 'including' the air conditioner could be causing the inside breaker to 'trip.'
One way to check this would be to 'un-plug' whatever else you had on the inside breaker - and then run your air conditioner and see if the breaker trips. Let's say you have the refrigerator and the air conditioner on the same inside breaker. You suspect the refrigerator is causing the inside breaker to trip - so you unplug it - and then turn on the air conditioner. "Now" it does not trip the inside breaker and assuming you have the proper fuses in the outside disconnect - you could safely say the air conditioner is ok - but - the refrigerator might be on the blink.
It's also possible that you just have too much on the inside breaker and you need to plug the refrigerator in to another outlet.
Still, if it was me - I think I would really think 'hard' about calling a Service Tech out - and let him/her diagnose the problem.
Hope this helps.
Jun 12, 2010 | Heating & Cooling
Second hand Fisher & Paykel keeps tripping power off
sound's like you have dead short to ground in the start mode of the compresser.
Nov 22, 2009 | Maytag MSD2651 HE Side by Side...
We put in a new thermastat and now the ac wont work. Is there a fuse?
R--redwire-power y-yellow wire -cool g-green---fan w-white -heat. If you turned it off &back on too fast, then you probably did blow the fuse on the outside unit or triped a breaker, check your fuse box ,or on the outside wall, theres a gray box called the disconnect box that sometime, house 2- fuses or a plain pull-out with no fuses.
Sep 04, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
