Question about Samsung HL-S5087W DLP TV
Samsung HLS5687W XAA will not stay on
I have a Samsung HL S5687W XAA DLP made in 2006. This set will not stay on. I push the power button on the TV. The Map light flashes brightly and the adjacent light flashes dimly. The projection bulb is on. The flashes last about 15 sec followed by a strange tone and then the light shuts off. What could be wrong?
I believe the bulb is good and the ballast is good.
I cleaned the fans and observed both fans turning.
I remove the light assembly door and manually hold down the blue switch.
Problem still persist...
    New Friend:
  • 46 Answers
You might have the problem with your standby processor on it, that needs samsung technicians.
Posted on May 03, 2017
Slinteriors
  • 8617 Answers
SOURCE: Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Posted on Apr 09, 2008
SOURCE: my samsung dlp tv hl-s5687w
I had the exact same problem with my TV turning off for no reason. If those two lights are blinking in the front it means your TV thinks the lamp door is open and shuts down. In my case i had to open the door and adjust the spring lever because it was not making good enough contact.
Hope that helps.
Posted on Dec 09, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung DLP HL-R5667W lamp won't fire. Changed
Was the replacement lamp the same part number as the original as there are different arc gaps for different lamps and the wrong arc gap will cause the lamp not to light. Since the ballast is powering up the lamp should light if the baalast is matched to the correct arc gap of the lamp being used.
Posted on Nov 27, 2009
SAMUEL011
  • 39 Answers
SOURCE: samsung HL-S5687W dlp tv, the picture is darker
Hi
Well for what you describe it sounds like the symptoms of a worn out lamp giving you the last kicks,basically the the lamps are design to go for 6,000 to 8,000 lamp hours if they're Phillips and a generic lamp could give you 3500 to 4500 lamp hours so with this in mind you could search for a new lamp at Discount-merchant.com or you can go to Ebay also you can go to www.fixyourdlp.com for more troubelshooting
Please rate this if it was helpful.as I do this for free.
Regards
Posted on Jan 05, 2010
Testimonial: "Very prompt solution to my problem, thank you. "
SOURCE: MY SAMSUNG HL-S5687W TURNS OFF BY ITSELF.
From what I have read the most frequent solution to this problem is that the lamp door has become loose and that microswitch on it needs to be reset. Simply loosen the screw to the lamp door and open it a little bit and then close it again making sure that the door is closed tightly and retighten the screw.
Unfortunately, the second most common problem is that the main DMD digital board has developed a problem which is much more expensive to replace.
Raven
Posted on May 10, 2010
Is there a manual for samsung dlp tv 5687- location of fan#2
http://www.manualslib.com/manual/510316/Samsung-Hl-S5687w.html
Oct 17, 2015 | Samsung Televison & Video
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
When we turn the TV on, a red light starts to blink but no image or sound is displayed. How can this be fixed?? And What is causing this? my TV model is HL-s5679w
The Blinking light is an error code, most likely you just need to replace the bulb which is fairly easy, there is an access panel on the back and you should be able to replace your self. A new bulb should include basic instructions here is a link price is $110
http://www.buy.com/prod/samsung-hl-s5687w-hls5687w-bare-lamp-bp96-01472a/q/sellerid/28565179/loc/111/215199305.html
Sep 14, 2010 | Samsung HL-S5687W 56" HDTV
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
TV has dark streak on one side of screen.
Your TV has a bad light tunnel. This part is inside the light engine. A qualified tech will have to replace it, but the part is available. Once it is replaced the TV will be as goog as new. Please take time to rate this solution and let me know if I can be of further assistance
Dec 13, 2008 | Samsung HL-S5687W 56" HDTV
TV SHUTS OFF
ask for an estimate of cost before the repair is completed,poss. fan or color wheel,power supply.
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W DLP TV Logo
367 people viewed this question
Henry  Thomas
Henry Thomas
