Question about Toshiba Satellite L25-S119 Notebook
Toshiba laptop battery or AC/DC adapter
My computer has no power. How do I know if the battery is dead? Or if the AC/DC adapter is dead and not supplying my battery with power?
Audio codecs
Posted on Apr 19, 2008
Audio: PCM 8000Hz stereo 256Kbps
    Scholar:
  • 144 Answers
Step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
Jan 25, 2013 | Toshiba Satellite Computers & Internet
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
Battery problem not working or the power button not working,,Why?
Feb 09, 2011 | Toshiba Computers & Internet
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
My battery doesnt hold a charge
That means that you will be needing a new battery. I would suggest that when you get a new battery (hopefully from the manufacturer) What you should do it charge it, and don't recharge it untill it has completely dead. That will help to preserve the battery longer.
All The Best,
Ryan Frame
Creative Energy Associates Technical Center
Jul 09, 2009 | Toshiba Satellite L45-S7423 Notebook
Toshiba Laptop not Taking Charge
ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
Jun 18, 2009 | Computers & Internet
AC Adapter dosen't work
Check if there is a green light on the Adapter, on the black Box, if it is not there, please get a new adapter
Jun 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A105
The most common problem on these units is the ac connector solder joints break away from the motherboard. If you're sure the ac adapter is working, and the correct one, and it's not charging the battery (assuming the battery is good), it's most likely the problem. They don't have to appear loose to be loose.
Otherwise, it's motherboard time, or a loose screw, etc has caused a dead short on the board.
Good luck, if you have additional info, let me know.
Feb 09, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite L25-S119 Notebook Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
