Question about Yard Machines Garden
No power going to starter. Changed ignition switch & clutch switch.
  • 760 Answers
Check seat switch. Before replacing parts use a voltage tester to see what is working. If you don't have one you can buy a cheap one or even a test light. Test first to the small wire on the solonoid for the starter and see if you have voltage. If not check the battery term on the solonoid and be sure it is hot, probably is. Then go back up the line. The seat switches are probably most trouble, and then the clutch pedal switch. Some models have to have the blade disengaged also. If you test everything and don't get a reading check for a blown fuse. If you do get readings at the starter solonoid, then maybe bad solonoid.
Posted on Jul 11, 2010
We put the new starter on today, and the car still won't start. We are thinking it's the starter relay. What else can be wrong with the car? can you please help us we depend on that car. Thank you
There is no starter relay shown in a wiring diagram. The only thing between the ignition switch and the starter solenoid is the park/neutral switch (or the clutch pedal position switch on manuals).
Do the warning lights and gauges come on with key on? That would verify power is into the switch and being sent out. The small purple wire on the starter solenoid should have power on it when the key is held in start position. If it does, recheck your starter and battery connections. When the purple wire energizes the solenoid, the starter motor should crank the engine.
If no power on the purple wire in start, check the neutral safety switch or the clutch switch if a manual. The start wire out of the ignition switch is a yellow wire, and the wire from either safety switch to the starter solenoid is a purple wire.
(The power to the ignition switch is from the 50 amp Ignition fuse in the under hood fuse block.) See? The positive battery cable is connected to the starter, but not to the starter motor. When the key is in start, the hot purple wire energizes the solenoid and the battery cable is connected to the starter motor.
May 24, 2014 | 2001 Chevrolet Cavalier
Chevy Tahoe Intermittent No Crank
I will try to help, powell. Your start circuit from battery to ignition switch to starter-and back to battery. You may need to check every thing here, including the grounds, for a loose connection, or just possibly a failing part.
If only complaint is intermittent starter action, and no other problems with ignition switch, let's assume switch is good, so battery to ignition switch is good. Now from the switch, a yellow start wire goes to the instrument panel fuse block, to "crank" fuse #8 (10 amp), from there a purple wire goes to the safety switch. If manual it is a clutch pedal position switch (simple on/off switch-when clutch down switch is on). If automatic, purple wire goes to Transmission Range Switch on the transm.-in park or neutral the purple wire has continuity in and out of switch.
From that switch, the purple wire goes to the starter relay (under hood fuse-relay center). Now the relay: purple wire in start will energize the relay- wire goes to coil side of relay, and then coil side goes to ground. On relay power side, the power feed is a red wire-and it is the same red wire that initially sends power to the ignition switch. A 40 amp fuse in fuse-relay center sends power to ignition switch, and a splice goes to the starter relay as the power feed for relay. When relay is energized, contacts close, and power is sent from relay to the starter solenoid, again on a purple wire. When solenoid contacts close, starter motor is connected to the big battery cable on the starter.
There is your start circuit. try a new or different relay, try a new or test the clutch switch (or transm. range switch). Buy a $5 test light and use it to check where power is lost when starter won't operate. Hold key in start and check if fuse #8 is getting power. Check the safety switch, with key held in start, the purple wire should be hot. Check if relay has a power feed (pull relay out and check terminals) and if relay coil has a power signal in start. Check the relay's coil side ground. If that ground is intermittent, relay won't work.
When it won't start, use a test light, you should be able to find it.
Good luck.
Jan 10, 2014 | 1997 Chevrolet Tahoe
I have a 92 sentra lights come on but when i turn key nothing happens. Starter good ,relay good, head lights don't dim when you turn key . Car won't turn over at all
If by lights, you mean the dash lights come on, then ignition switch must be getting power. If dash is not working with key on, check the 30 amp fuse link which powers the ignition switch.
If switch is good and starter is good, the start wire from switch goes to, if automatic, to inhibitor relay (the park/neutral function) and then to starter. There is also an inhibitor switch on the shifter or on the transaxle that turns on the inhibitor relay when key is on and shifter in park or neutral. The inhibitor switch is powered by a 10 amp fuse D.
If you have a manual transmission, the start wire from ignition switch goes to the clutch interlock relay and then to the starter. This relay is turned on by the clutch interlock switch on the clutch pedal.
You can check for power on either relay, the inhibitor relay or the clutch interlock relay, with a test light. Pull the relay out, have the key held in start position. Now both relays would have power showing on two terminals where the relay plugs in. If inhibitor relay only has power on one terminal or no power at all, either ignition switch is not sending power or fuse D is out or the inhibitor switch is not working right. If clutch interlock switch does not have power on two terminals either the ignition switch is not sending power or the clutch interlock switch is bad.
If the relay checks are good, check for power on the small wire to starter with key held in start. If you have power there, the starter solenoid must be out.
May 08, 2013 | Cars & Trucks
How can depressing the clutch engage the starter ?
It sounds like current is feeding into the start wire off the switch. Trace the wire from the clutch switch to the ignition switch connector. Does the wire look good? Examine closely the connector and see if you see a burnt terminal, or some broken plastic in the connector, some way for the start wire to pick up current. If you see nothing wrong, IDK, probably will need a shop to chase the wiring down and find it. I don't know if a bad starter relay (stuck on) could do that, likely not if it only happens when you depress clutch and have clutch switch on.
Good luck.
Dec 31, 2012 | 1991 Chevrolet C1500
1990 HONDA ACCORD WON'T TURN OVER TO START BUT IT WILL ROLL START. I HAVE CHANGED THE ALTERNATOR AND TESTED THE IGNITION SWITCH STARTER RELAY SEEMS FINE CLUTCH SWITCH SEEMS FINE MAIN RELAY IS FINE
About the only thing you didn't mention was the starter itself. You could have it tested. But before that, try to see if you have power on the small wire to starter solenoid on the starter, when key is held in cranking position. Pull the small wire off and check for power with a multimeter or a testlight while someone holds the key in crank. This is the signal wire from ignition switch that closes the elec. contacts inside solenoid so the starter gets full power from the battery to spin. (This wire also is in the circuit with the clutch switch and the starter relay.) If you have power on this wire in crank, it is very likely the starter is bad. If there is no power, check that circuit out. It is losing power somewhere from switch to starter solenoid. Good luck.
Jul 06, 2012 | 1990 Honda Accord
1992 honda accord wont start when clutch is depressed
Can you push it off and pop the clutch in 2nd gear to start.
May 01, 2017 | 1992 Honda Accord
88F250 4x4 5.8L FI 5 speed. A friend has this & the starter went out. I replaced it & the solenoid. No big deal right? I returned it & the next day he called me & told me that the...
Its a solenoid...it engages the bendix and truck starts...bendix should retract because power to it gets shut off by ignition switch going to "run".
Only way bendix would stay engaged or get a signal to keep turning ???
Bad contacts in ignition switch...maybe ??
Start relay in under hood power distribution panel has hot or welded contacts ?
I've gotta think about this one...hope this gives some help...
Jul 30, 2011 | Ford F-250 Cars & Trucks
94 civic wont start, only if i push start it. changed starter and ingnation swith.
SOUND LIKE FAULTY STARTER CLUTCH INTERLOCK SWITCH LOCATED NEAR THE UPPER END OF THE CLUTCH PEDAL OR YOU HAVE A FAULTY STARTER RELAY.CHECK TO SEE IF POWER GOING TO THE CLUTCH INTERLOCK SWITCH WIRES WHEN CLUTCH PEDAL PRESS DOWN. IS YES SWITCH IS BAD.IF NO POWER GOING TO CLUTCH INTERLOCK SWITCH YOU HAVE FAULTY STARTER RELAY OR BLOWN STARTER FUSE.
May 04, 2011 | 1994 Honda Civic
1981 yamaha midnight special 850cc. starter button and kill switch not working but lights etc are working. no power from the start button. battery fully chaged? started after chaging the throttle cable.
If no power going to kill switch check Ignition fuse, sidestand ,clutch & neutral switches.
If all OK suspect the starter cut-out relay
Ride Safe
Bike-Doc
Sep 29, 2010 | Yamaha TRX 850 Motorcycles
1992 Dodge Stealth Starting Problem
It could be a problem that you can test quickly. You'll need someone to turn the ignition switch for you while the car is raised so that you have access to the starter. There is 1 small wire going to the solenoid from the ignition switch, it controls when the starter engages & is only supposed to light when the Ignition switch is in the start position. If when the key is in the start position you have voltage there, the switches are all working. By switches I mean the Ignition switch and one of these depending on the type you have.
There is a neutral safety switch on automatic trans. & a clutch safety switch on manual transmissions, but those are the only safegaurds betweeen the ignition switch and the solenoid.
While you're under the car, if the solenoid wire is getting power, test the bottom large lead going into the starter & see if it's got power. If so and the starter isn't turning, you either have a bad starter or some bad connections in the starting system.
Make sure the terminals and both post are clean & protected with a good coat of grease or vaseline. You should always remove the Neg.(-) cable to disconnect the power supply and prevent sparking or shorting while working on the wiring or charging the battery.
You would want to just check all of your connections next, even a bad ground wire going to the block could be causing the problem. I believe you will find a main ground and a minor ground wire on the transaxle assy, one specifically on a bellhousing bolt and those grounds need to have clean contact.
good luck.
Aug 05, 2008 | 1992 Dodge Stealth
Garden Logo
165 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
