Ht vision nv177b turns on for a millisecond then goes blank and green led flashes
    President:
  • 2,185 Answers
Hello there,
Make sure the processor and the processor is tightly locked on your motherboard. Also, try to unplug your computer by pulling out the power cord; wait for like 10 minutes and power it back.
If the above does not work, please let me know.
Posted on Jul 11, 2010
  • 3 more comments
  • flightcomman Jul 11, 2010
    the problem has to be in the monitor not the computer as i am using a different monitorof the same model and it works fine. thanks bill
  • virtualhost
    virtualhost Jul 11, 2010
    Oh, I thought it was a board since you posted in the Motherboards section. But anyway, thank you for your additional information and clarification. Yes it is the monitor that is at fault. It has a hardware problem with on the inside. Upon startup, the system detected a problem and thus the auto-shut off feature the monitor activated to protect itself from further damage.
    The green led blinking status on the monitor if often shows a fault on
    the power supply to the monitor. This is often complicated but if you can, open the cover of your monitor and see the power supply area
    for any capacitors that is bulging or leaking; look on the entire board as well. These capacitors needs to be replaced in order to fix the problem. However, if you are not technically skilled doing electronic jobs, touching these capacitors could harm you, and thus you need to take this to a computer technician. If you monitor is still under one year or under warranty, i would suggest that you also avail the warranty, and take it to an authorized service center to save cost of repair.
    Please let me know if you have further questions.
    virtual host, i am familiar with power packs and blown capacitors. i will open case and check for tthis problem and let you know my findings. thanks, flightcommander
  • virtualhost
    Thank you flightcommander, I appreciate of you letting me know your findings. :)
    virtual host, i took back of monitor off and see no blown capacitors. when i turn unit on i see a little round circle light up near top center of rear of unit and in front i see rgb light up on left top of screen for just a second then nothing and no noise is heard. what do you think would cause this. thanks, bill
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
Yukon Ranger 5 x 42 night vision goggles just stopped working, I put in new batteries, but when I press the ON button the on light, which is red, just flashes maybe 10 times and then all goes black. ???
Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
Jan 29, 2011 | Yukon 28041 Binocular
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi, I have a set of Hope Vision 2 lights running off the type 2241 2 cell Li-ion charger. Although I know the battery pack is low on power (lights giving warning flash) when I plug in to charge it only...
how many times have you recharge the batts some need to be run down completely to get the best out of them.. You might consider changing the batts as they could be taking charge but not holding it..
Aug 04, 2009 | Epic Hope Vision 2 Two Led Light Mtb...
PS2 Reset led
same thing is happinin to mine
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Computers & Internet Logo
Alun Cox
David Payne
David Payne
