Question about GE Spacemaker JVM1640SJ Microwave Oven
Product JVM1440WH04 - Heats but internal fan seems to not be working
Had microwave as a replacement for about a year (Brandsmart replacement issue) but only installed it a few days ago. Worked fine but now internal fan seems to have stopped (heats food but gets very hot inside). I don't know if we would be able to get any help from Brandsmart as we didn't use the appliance immediately (we had another one and saved this till we needed it).
a) would it be expensive to fix?
b) is is dangerous to use it in the short term?
Thankx
  • LMGreen Apr 19, 2008
    my model is JVM1443wk and it seems to have the same problem. Don't want to use it till I have an idea of what might be wrong.
  • GE Master
  • 9,098 Answers
GE Customer Service is at GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
I recommend that you contact them to find a local GE-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
SAMSUNG MICROWAVE FAN STOPS WORKING. COULD IT JUST BE THE FUSE?
I would guess, I do not know for sure that the fa motor seized and blew the fuse, during the process the internal protection device on the fan motor opened giving you exactly what you are describing.
Nov 27, 2014 | Samsung Microwave Ovens
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Microwave oven does not heat up
This seems to be a common problem with microwaves, the problem is likely the magnetron "heats food" and the heart of the system. If the oven is five years or more I would suggest a new one.
Mar 05, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
Maytag MMV4205BAS OTR microwave does not vent internal steam and the microwave shuts off. It takes about 15 minutes to reset and power back up. What part is bad?
I have this same microwave, and I'm having trouble with it shutting off. It use to go back on, but now it doesn't work at all. I tried replacing the two fuses under the panel, but that wasn't the problem.
After some research and calling vendors, I believe the issue is most likely due to a failure of the magnetron tube which supplies the microwaves. Take it to a repair professional to get a cost estimate on fixing.
This model of Maytag seems to have BIG problems! It's either the tube is out, the turner doesn't work, or it just goes dead. Usually it's after 2-4 years of service. Poor quality... Maytag lost a lot of clients with this product!
Apr 12, 2009 | Maytag MMV4205 Microwave Oven
No power to microwave, changed fuse but still nothing!
There is an internal fuse and internal TCOs (thermal cutouts / thermostats) any of which can interrupt the power to the unit.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
They can help you find your
your nearest GE-authorized servicer.
Dec 28, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
127 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
