Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have WD5000H1B-00, 4208A, R/N:A1C, S/N WCASU3196117. I HAVE MIXED UP MANY TRANSFORMWERS AND NOT SURE THE ONE FOR THIS BACK UP . WHAT IS THE DC INPUT . 12v ???A
  • swain334 Jul 11, 2010
    Is a good product,hope it works again after it wasdisconnected
    President:
  • 2,185 Answers
Hello there Swain,
The DC input 12 v is the slot where you plugin your AC adapter. You can see images below.
For a detailed information with illustration, you can check out page 11 of this manual:
http://products.wdc.com/library/UM/ENG/4779-705013.pdf
Hope this helps. Please let me know if you have further questions.
Thank you for using FixYa.
Posted on Jul 11, 2010
    Is the DC power output from the transfoermer 2A or 1.2A as I have both and which to know which one to use or is it of no consequence?
  • virtualhost
    virtualhost Jul 11, 2010
    You mean the adapter? If they come in the package, then they are safe to use.Actually is it of no consequence as long as your input voltage matches the power specifications of 100V to 240V AC.
What should tour sygar test for normal
A1C: 7%
A1CA1C is a test that measures a person's average blood glucose level over the past 2 to 3 months. Hemoglobin (HEE-mo-glo-bin) is the part of a red blood cell that carries oxygen to the cells and sometimes joins with the glucose in the bloodstream. Also called hemoglobin A1C or glycosylated (gly-KOH-sih-lay-ted) hemoglobin, the test shows the amount of glucose that sticks to the red blood cell, which is proportional to the amount of glucose in the blood.X may also be reported as eAG: 154 mg/dlmilligrams (MILL-ih-grams) per deciliter (DESS-ih-lee-tur), a unit of measure that shows the concentration of a substance in a specific amount of fluid. In the United States, blood glucose test results are reported as mg/dL. Medical journals and other countries use millimoles per liter (mmol/L). To convert to mg/dL from mmol/L, multiply mmol/L by 18. Example: 10 mmol/L ?¯?¿?½ 18 = 180 mg/dL.X
  • Before a meal (preprandial plasma glucose): 80-130 mg/dl
  • 1-2 hours after beginning of the meal (Postprandial plasma glucose)*: Less than 180 mg/dl
  • Aug 05, 2017 | Cars & Trucks
    I have a older bolens garden tractor that over charges the battery
    Are you sure you did not mix your wires or they were mixed when you bought it? Two of the wires that come out from under the flywheel should be the same color go to the outside spades on the regulator and the center spade is to the battery , probably by way of through a gauge and key but for test purposes it will be the wire that feeds about 13.8 DC volts to charge the battery, the two outside spades on the regulator that have wires that go back under the flywheel are ac voltage anywhere from 18 to 38 volts depending on RPM of engine . Yours is a voltage regulator, Rectifier, converts it to DC and regulates it at 13.8 volts DC
    Dec 15, 2016 | Garden
    Can AC and DC Power Modules Be Used in the Same Switch?
    Fixed Switches Product Series Model AC and DC Power Module Mixing S3700/S5700/S6700 S3700-26C-HI Supported S5710-28C-EI Supported S5710-52C-EI Supported S5700-28C-HI Supported S5700-28C-HI-24S Supported S5700-EI (non-PoE) Supported in V200R005 S5700-SI (non-PoE) Supported in V200R005 S6700 Supported in V200R005 S5710-HI AC and DC power modules cannot be used together, but 350 W and 1150 W AC power modules can be used in one switch. S5720-HI Supported Modular Switches · When a switch does not use a PoE power module:
    AC and DC power modules cannot be used together in the same type of power slots. Power modules with different power values cannot be used together either.
    · When a switch uses a PoE power module:
    Version PoE Power Module System Power Module V200R005C00 and earlier versions AC AC DC power module not supported - V200R006C00 and later versions AC AC DC DC AC DC ·
    AC and DC power modules cannot be installed in the slots of the same type (system or PoE) in the same switch, and the power modules of different power values cannot be used in the same switch.
    S5720 Switch Thunder link com
    Oct 27, 2016 | AC Cars & Trucks
    I did a factory reset on my A1CS fusion 5 tablet now when i switch on ijust get a flashing ANDROID screen, when i press menu it reverts back to the flashing screen
    Charge it overnight and try again give it 24hrsif it don't work drain the battery until it resets it self then charge it 24+rs
    Jan 09, 2015 | Tablets & eReaders
    CAN NOT GET POWER TO THE TRANSFORMWE
    The unit plugs into the wall. that is the way that it gets power. If you are not getting power out of the transformer then you should replace it.
    Sep 27, 2014 | MG Electronics MGT925CC Plug In Class 2...
    I need an instruction manual for A1CS FUSION5
    You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
    This is for car and truck problems related to factory installed systems not add on aftermarket systems.
    This post can't be removed or moved, please re-post the question in the correct product category. Thanks
    Oct 30, 2012 | Cars & Trucks
    I need a manual for the A1CS X220 tablet 10.2
    We do not have the owners guide for this make and model.
    Apr 27, 2012 | Computers & Internet
    Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
    742 people viewed this question
    Top Western Digital Computers & Internet Experts
    Alun Cox
    Marvin
    Marvin
    Mike
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
