Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I think we all bought a piece of junk with the Badger 5.
  • Ace Hardware Master
  • 43,501 Answers
Maybe....anyone can get a POS at times...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Sep 29, 2010
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
How to Dismantle an Under the Sink Garbage Disposal
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
Sep 14, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I have a badger 5 desposaland it is leaking out the bottom by the cord,is there a seal I can buy,or can i even get to it,or just junk it and get another. Thanks Neal
Once the disposal is leaking there... it will cost more to repair then a new one will cost...
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I am looking to replace my insink garbage badger 5. 1/2hp unit. I am thinking of upgrading to a quieter unit such as the Evolution EXcel. Notice that this unit is 1 HP and runs on 120volts. Can I use...
Yes, the fit is pretty universal, and the circuit supplying power to the badger should be sufficient for the new one, which draws 10 amps. But you should take a look at the dimensions on the sheet at this link to confirm that you have space for it.
http://www.insinkerator.com/pdf/SpecSheet_XL.pdf
Dec 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Attaching dishwasher drain hose.
Are you talking about the "barbed attachment" on the disposal? If so, simply use a screwdriver and hammer to knock it out. Make sure you reach into the disposal (through the sink) to get this piece of plastic out after. Good luck
Jan 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hi. I had a piece of plastic fall down my insinkerator badger 5 and jam the motor. I manage to turn the motor with the allen key to free the piece, but it's still in there making a lot of noise and I'm...
Hi, Use a needle nose plier to get it out or take it down and dump it out...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Dec 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have an insinkerator Badger 5 that is making a loud noise. I can see that there is a piece of white plastic wedged in there - probably a toothpick put in by mistake - I detached from sink and the object...
try taking a long screw drive and turn the unit backwards, if you can get it to move a little then try to unwedge the peice with long needle nose plyers,should work .
Jun 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have an Insinkerator Badger 5 garbage disposal that is about 4 years old. It has started leaking water from the very bottom right from the electrical connection. Do I need a new unit or is this something...
Press a piece of chewing gum in the leaking area--and if that doesn't do the trick --which it wont of course Throw the darn thing away--buy a Evolution Elite by Insinklerator--pretty quiet about $200.00 though--worth it..
Jan 10, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
63 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
