Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi with green screen.
I have a Mitsubishi 48" HD 1080 series. it shut itself off and when i turn it on the screen is wavy and green for 5 to 10 secs. then shut off again. can you help?
  • Mitsubishi Master
  • 8,457 Answers
This tv have a problems known as a covergenece problems,it dead.The tv convergence board must reqiure it 2 STK convergence ICS and some or all it resistors to change to solved the covergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Jul 11, 2010
On an older Mitsubishi 1080 hd rear projection tv what does it mean if once its warmed up screen gets wavy and shuts of
Either the power supply or the inverter. If you have never checked the color guns then I would check that first.
Dec 25, 2014 | Televison & Video
I have a Mitsubishi HD 1080 series and it will not turn on. Does that mean I need to replace the bulbs?
The model indicated here has a self check if the green power light comes on f o r a few seconds and goes off, do you get the power light briefly or not at all?
Aug 27, 2012 | Mitsubishi WS-55805 55" Rear Projection...
When I push the power button the timer light glows green for 5 seconds or less then shuts the tv off. I have a Mitsubishi HD 1080 series, 48". How do I fix this?
A fuse is blown inside usually and its going into shutdown. If its f9a04 or f9a05 then its likely convergence (the most common issue). Check them with an ohm meter. Here is a tech guide, it talks more about when the tv will still come on, but it may be helpful.
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 12, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS 48311 48'' HD 1080
There no longer available from mitsubishi, but the following link may have them or can get them. leave them an email with the model number of your set and what youre looking for.
http://servicemanuals.vstore.ca/
Jun 08, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
269 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
