Question about RIM BlackBerry Bold 9700 Smartphone
Blackberry bluetooth bug?
I have blackberry 9700...
my bluetooth cannot be activated. it started happening today, but not sure exactly when.
this morning i was installing and upgrading few apps in my phone and that's obviously what I think it caused the problem.
i did the following changes this morning... i installed Craigslist App (by Movela), I upgraded the Dictionary.com app from v1.0.1 to v1.1, I unistalled BeejiveIM, and finally I installed QuickLaunch.
I dont know at what point did the bluetooth was broken. It was not until later on the day when I wanted to use it that I found out.
The problem is when I go the the "manage connections" screen and I click on the checkbox for the bluetooth it doesn't enable the bluetooth. instead, it just waits for couple seconds in a grayed-out font, and then it just doesn't do anything.
what could be the issue?
Regards,
AGL
    President:
  • 1,561 Answers
There are couple of reason that can cause this not to be responding, i advice you first carry out reset option on the blackberry to see, if it will fix the abnormality, power off the phone and power on back after few minutes, while the phone is booting/loading, pull out the battery and wait a while before putting the battery back and power on, see if it fix the problem, if not, proceed with the below procedure.
  1. On the BlackBerry Home screen, click Options and then select Bluetooth.
  2. Display the menu and select Options.
  3. In the Discoverable field, press the spacebar until the field displays Yes.
  4. Save the changes.and try connect again.
Take care.
Posted on Jul 11, 2010
  • zokich Jul 11, 2010
    Thanks for your response. However, I cannot fix the problem that way. I did just try the rebooting steps that you described and it didn't help.
    As for the procedure to change the bluetooth options, I know what you mean but there is no "bluetooth" in the list of options....
    when i go to the blutooth configuration button from the direct access in one of the folders to get to where you configure the bluetooth, the screen just kindda freezes for a little bit, and I have to press the red button (hangup call) to get out of there and at least go back to the home screen.
    any other suggestion,
    can we just talk? is easier than typing..
    regards,
    AGL
    Take
    care.
  • Sulaimon Jimoh Olayemi Jul 11, 2010
    I advice you update the bluetooth of your phone as well, cause i can see that it is either it is corrupt or the update done are not compatible, update the bluetooth on your phone and see if it fix the problem. note, i strongly advice you scan the phone from virus as well, because it is possible that during the update the phone as contacted virus, ensure the phone is virus free before proceeding by scanning it.
    Take care.
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    I can't enter the ringtones/alert profiling options,or I can't enter to "set ring tones/alert" so I can't change my sound alert anymore on my blackberry onyx,what is wrong? I've tried to restart it and...
    I had the same exact problem today and figured out it happened after I upgraded to the newest version of Nimbuzz...I uninstalled Nimbuzz and it worked again so it must be a Nimbuzz bug, at least for me!
    Oct 05, 2010 | RIM BlackBerry Bold 9700 Smartphone
    BLACKBERRY 9700 BLUETOOTH CONNECTIVITY
    in the media menu, press the bb button then select receive via bluetooth
    May 02, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Can't use wi-fi without data plan? on blackberry bold 9700, can't transfer pictures from laptop to blackberry either?
    May I recommend you check the version of firmware that your BlackBerry Bold 9700 is running?
    Every release of system software works out bugs and 'funny' behavior, so you may find reflashing it will solve your wifi and data transfer problems.
    The latest version is available through here.
    Mar 24, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Setup wizard freezes when I try to activate
    You might want to check which version of the the BlackBerry System Software you are using.
    Having the latest version will ensure that you are running a platform with as many bugs worked out as possible.
    This page will provide a link to the latest multi-language version of BlackBerry System Software.
    Mar 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Blackberry bold 9700 Bluetooth problems
    Many quirky behaviors for these devices are fixed every time a new software version is released.
    You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
    The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
    Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
    Mar 05, 2010 | RIM BlackBerry Bold 9700 Smartphone
    My new BOLD 9700 doesn't lock to some bluetooth devices ( I know the phone is new but I had a 9700 before and that did lock to all of the devices this new phone isn't ) .... Please help, thanks Alex
    You might want to check which version of the the BlackBerry system software you are using.
    Having the latest version will ensure that you are running a platform with as many bugs worked out as possible, including bluetooth functionality and compatibility.
    Mar 03, 2010 | RIM BlackBerry Bold 9700 Smartphone
    When i unlock my bold 9700 sometimes the display on the screen will be messed up. Shows a ghost set of icons on the home screen. Sometimes i'll try to type on the phone and the characters will be messed...
    May I recommend ensuring you are running the most recent system software and firmware for your BlackBerry Bold 9700? This will ensure as many bugs as possible have been worked out of the phone you are using.
    The latest BlackBerry Bold 9700 system software is available through here.
    Feb 15, 2010 | RIM BlackBerry Bold 9700 Smartphone
    When I request 'more' of a text email, the system skips some words/characters rather than picking up from where it was up to. Bold 9700 Blackberry.
    May I recommend upgrading the firmware/system software of your BlackBerry Bold 9700 to the latest version? This will ensure you are using the most bug-free environment possible.
    Unable to pair bluetooth Plantronic 975 with BlackBerry 9700
    On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
    Make sure your Plantronic is in pairing mode.
    On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
    Feb 10, 2010 | Cell Phones
    RIM BlackBerry Bold 9700 Smartphone Logo
    258 people viewed this question
    Top RIM Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jason
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
