Question about Epson Stylus C60 InkJet Printer
No response Hi there, My C60 printer red & green lights are both flashing and I cannot get the carriage to move to replace the cartridges
  • showsurfer Apr 19, 2008
    UNFORTUNATELY NOTHING WORK ONLY THE ON/OFF BUTTON
  • hongluo May 26, 2008
    Epson stylus C42 . i have got the same problem. it stopped printing, so i tried to replace the cartridge. It only left the two bottons' light flashing. It wouldn't allow to change the cartridge. I mean the ink cartrifdge box wouldn't move to the middle from the right hand sidre corner. I need some solutions please.
  • 61 Answers
If you´re pressing the ink button and the carriage still does not moves is cause the level of the ink is low, but it does not finished yet. You must use the printer more, then the red light will stop to blink and hold on, then you´ll be able to change the cartridge.
Posted on Apr 19, 2008
  • Antonio Cirio Apr 20, 2008
    So, your waste pad is probably full. You need to replace the waste pad , then reset the waste pad counter. It will turn your printer able to print again.
Printer is running out of ink. To put new cartridge in I lift the lid and normally cartridge carrier moves over to left allowing replacement of cartridge. Today no movement---why? Green light is flashing...
Hi there.
It's probably jammed by dirt. Unplug the printer, move the carriage out of the way and clean thoroughly the metallic rails the carriage runs to using a cue tip.You might have to move the carriage multiple times to clean it totally. Finally spread a little fine grease over the metallic rail and again move the carriage from side to side. Now plug it in and try using it.
Let me know what happens.
Sep 11, 2011 | Epson Stylus C46 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
When the carriage moves to the right,there is a loud crunching noise, red light comes on.
Check to make sure, no staples or paper lodge.
Check it with a flashlight.
Good Luck..........
Jan 22, 2010 | Epson Stylus C60 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Green light flashing Red light on
with regards to the status of the lights., its either the cartridges that you installed is not recognized by the printer's print head or cartridges are defective.
try these steps:
if all the inks are new take them out and get an eraser and rub the small chip gently so as to clean the contacts of the chip ( don't touch it with your finger ) reinsert the cartridges in the printer and allow it to charge.
Apr 07, 2009 | Epson Stylus C60 InkJet Printer
Just re-installed the driver and then the Epson C60 printer/scanner. Doesn't print is #1 problem.....shows the printer as "ready", but doesn't print. Other problem is need to change a color cartridge and...
Hi
Have you tried pressing the maintenance button, press and hold it up until the cartridge holder moves to the place where you can change the cartridge. are there any error lights as well on the printer? red or flashing light?
Hope this helps
Dec 20, 2008 | Epson Stylus C60 InkJet Printer
Carriage won't move over to install new innk cartridge
Personally. my carriage move (ink maintenance button) stopped working within the first month...i have this printer for almost 6 years now, I just manually move the carriage over by hand
Dec 16, 2008 | Epson Stylus C62 InkJet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus C60 InkJet Printer Logo
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
