Question about Fujitsu LifeBook A6025 Notebook
Fujitsu lifebook blinking battery led, bad ac adapter?
My FUJITSU does not charge or work. I plug in the original AC ADAPTER and there is absolutely no response the output of the original is 19v.
I tried plugging in my IBM 16v AC ADAPTER and the battery led blinks 2x then remains off.
Odd how it goes some kind of response with the IBM (less voltage) adapter. Can it be that the original 19v adapter is bad?
  • xxsicrokerxx Jul 12, 2010
    thank you my brother stopped by and brought his laptop and charger, and guess what his charger worked, the computer loaded up and is working fine.
  • 176 Answers
I would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Posted on Jul 11, 2010
I have a fujitsu lifebook A series, Model AH531/GF0, it will not receive current from my ac adapter. The computer is total blackout. What is the main problem of said lifebook?
Please check the voltage at the pin end of the laptop using a multimeter in the voltage range. If absent then there is fault in the adapter and must be opened to confirm or replace.If present then connect and check the voltage at the pin end of the battery terminal in the laptop , if present the battery is a suspect.Check this link: http://www.fixya.com/support/r5164850-laptop_power_supply
Jan 17, 2012 | Fujitsu Computers & Internet
My Fujitsu Lifebook AH530 says 'Plugged in, Not Charging'. Battery problems!? Its a new laptop that has worked less than 40 hours. And not quite clear about the functionality of the "Full" button...
Hey there my i have an answer for your question if you think that plugged in but not charging means anything related with the software is all rubbish, i had a brilliant answer just try few simple steps,
1) Try to change different wall outlet
2) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
3) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
4) Just download latest BIOS update from your computer manufacture website , Flash BIOS and check if the issue is resolved or not
5) If everything fails just try and check if the Ac adapter pin is burnt or not, you will see a black spot or something like a burnt spot on the Ac adapter pin of your laptop, if you see this just take any pointed device like Knife etc just scratch clean the black spot and once the black spot is properly cleaned then just connect the pin to the wall outlet and t see the Magic
Hey guys if you really think this works just post you comments or likes so that i will feel happy , really this things works on my 1 year old Fujitsu laptop and i have also worked for
companies like HP and Dell.
Mar 28, 2011 | Fujitsu (FPCBC21AQ) AC Adapter Battery...
Hi, my Fujitsu A1220 won't start up at all. I took out the battery to reset the laptop but when I put the battery back on or connect it via AC, it still won't start up. I see the Scroll Lock is brinking...
Here are some ideas to try.
1. Plug battery in and see by looking at the charging light if it's charging. The light should stay mostly constant during this process. If it is charging, then wait about 20 minutes. Unplug laptop and attempt to turn on with just the battery installed. If the laptop turns on, then you can be sure you have a bad AC adapter or a bad DC jack.
Uninstall the battery before attempting the next five steps.
2. Look for the light on the laptop that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, then it's possible you have a bad DC jack or the AC adapter needs to be replaced.
3. Try a different outlet. (I know it's obvious but it's worth a try).
4. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
5. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
6. Replace the AC adapter. Find and buy a compatible AC adapter online. You can usually find them reasonably cheap.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard. (This requires some technical know-how).
Hope one of these ideas helps.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Fujitsu LifeBook A1220, LifeBook A6210,...
Dear Sir My Laptop Lifebook FUJITSU ah530 shutdown suddenly, and also the battery bar on windows 7 says: plugged in not charging. What can I do my laptop shutdown suddenly?? Zuheir Sharafeldin
Hi there there was the same problem with my Fujitsu laptop as well you can try this step
5) If everything fails just try and check if the Ac adapter pin is burnt or not, you will see a black spot or something like a burnt spot on the Ac adapter pin of your laptop, if you see this just take any sharp device like Knife etc just scratch clean the black spot and once the black spot is properly cleaned then just connect the pin to the wall outlet and t see the Magic
Regards
Majid khan
Dec 13, 2010 | Fujitsu (FPCBC21AQ) AC Adapter Battery...
Hello my fujitsu e2010 jusr stop working it will
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Jun 06, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
I have a fujitsu lifebook that will not charge my battery. I replaced the ac adapter, and i replaced the battery and continue to have the problem
Bad power circuit on the motherboard. Usually part of the motherboard and thus would require motherboard replacement to fix the problem.
Nov 13, 2009 | Fujitsu LifeBook A6020 PC Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
P5010D does not start when pressing On/Off button
first is the ac adapter
next is the ac jack , if the pin is loose , or you have to move the adapter to get it to work, it could be bad jack
Jul 18, 2009 | Fujitsu P5010D (AWA061A90ED00422) PC...
Fujitsu LifeBook A6025 Notebook Logo
612 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
