Question about GE Spacemaker JVM1640SJ Microwave Oven
Need a GE microwave Bulb: 30 watt WBO2X4235, where may I purchase one ?
  • GE Master
  • 9,047 Answers
That would be part number WB02X4235 (with a zero in it, not an oh) and you can order it here.
Posted on Jul 11, 2010
Looking for 50 watt halogen bulb wb36x10213 for the microwave over the range
take the old bulb out and go to the hardware shop or the 1 pound shop
its a standard size
Aug 12, 2014 | GE Microwave Ovens
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
Apr 28, 2014 | GE XL1800 1100 Watts Microwave Oven
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Replacing light bulbs?
Replace the burned-out bulb with a 120 volt, 30-watt incandescent bulb (WB36X10198), available from your GE supplier
  • 1 To replace the oven light,
first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
  • 2 Remove the top grille by
taking out the 2 screws that hold it in place.
  • 3 Remove the charcoal
filter (if present) to access the light cover (see Remove Charcoal Filter section).
  • 4 Remove the light cover
located near the center of the oven that holds the bulb. Remove the bulb by gently turning. Replace with the same size and type bulb.
  • 5 Replace the light cover
and charcoal filter (if present).
  • 6 Replace the grille and
screws. Connect electrical power to the oven.
The full owners manual can be found here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40474.pdf
Mar 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
WHERE CAN I GET A REPLACEMENT
if the globe unscrews then you can find a replacement from any good hardware store. if the globe is fixed to the bayonet then its a sealed unit and you will need to contact your nearest ge repairer and order on through them by giving them the make and model number of the unit
good luck
Jul 12, 2010 | GE Advantium 120 Convection/Microwave Oven
Need to replace light on GE microwave model JE1540GN
Some models will have a small door on the cabinet that is held closed by one screw and others you will have to take the whole cover off. The bulb is easy to find and just screws in like a standard bulb but is a smaller base. Most are 15 Watt.
Jun 17, 2010 | General Electric Microwave Oven
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
I need to replac the bulb in my ge advantium. what kind of bulb
Hello. Use a 35 watt halogen bulb with a GY8.6 base. Lowe's part number 15797.
Regards, --W/D--
Apr 18, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile ModelJVM187OSK04 Serial # DM902972B The bulbs went out, they are 120 volt 20 watt. Can I use a GE 120 25 watt bulb as I am having trouble finding a 20 watt??
You should be able to use the 25 watt bulb as long as they are compatible with the socket they mount in... Hope that helps...
Aug 16, 2008 | GE Microwave Ovens
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
552 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
