Question about Lexmark X2500 All-In-One Printer
Have been trying to install Lexmark 2500, keep getting a message that states I must restart my computer. Have done that and still get the same message but the loading of the software does not occur.
  • daintyslim Aug 12, 2008
    wont let me sacn
  • 323 Answers
Try removing the drivers from c:\windows\system32\spool\drivers\w32x86 folder. Delete everything from that folder.
For Windows XP Navigate to http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:590:0:0&searchLang=en&os_group=WinXP&target=
Click on cjr2500EN.exe
for Windows Vista
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:590:0:0&searchLang=en&os_group=Windows%20Vista&target=
cjr2500EN.exe
Install the driver.
Posted on Apr 21, 2008
I have the lexmark X63 printer and I need to use it. I need to print something and I do not have the cd to get the driver. My lexmark 2500 has stopped on me so I was trying to use this one I had before I...
Depending on the age difference between your operating system and the printer, you may get some functionality by doing this:
Power down your computer system and then connect the printer. Make sure the printer has power and is turned on.
Restart your computer.
Windows may recognize it and install the appropriate driver. Watch the lower right-hand area of your monitor during the boot. If Windows sees it at all, it will open a message box and either tell you it is installing the driver or it will tell you to insert the disk that came with it (which you don't have.)
Going to the Lexmark website, you should find downloadable installation packages for virtually any printer they ever built.
You might create a new folder prior to trying to download and give that folder as the destination for the download. Normally, you will be able to start the installation procedure from within that folder.
Sep 11, 2011 | Lexmark X63 InkJet Printer
I owe a Lexmark Printer X2580 and I lost the instalation CD. I downloaded the file cjr2500EN.exe, I installed it, but when I try to send a fax I get the following message: "The fax driver is missing...
The Lexmark Fax Solutions software can be installed using the installation disc that came with your printer. Please contact Lexmark technical support for additional assistance.
Jun 18, 2011 | Lexmark X2500 All-In-One Printer
I've had my Lexmark x2580 installed on my new Acer Windows 7 machine for 6 months now. I kept getting a "please register" message but since it is about 2 yrs old & I'd already registered, I...
Make sure your print spooler service is running. This article in the Lexmark website about How to Restart or Reset the Print Spooler in Windows might help you enable the service again. If problem continues, please contact Lexmark technical support for additional assistance.
Feb 10, 2011 | Lexmark X2500 All-In-One Printer
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
Mar 15, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark 2500 Communication Error
try deleting the print job from the computer that sent the job first. then see if you can delete the job in the printer.
Sep 13, 2017 | Lexmark X2500 All-In-One Printer
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
When trying to install software for Lexmark x2580 it seems to hang part way through. Heve tried several times from disc, and downloaded software from Lexmark. Message in bottom right states 'a problem...
Hi ,
Definitely u install printer through connecting printer to pc .that's why the problem is occure........
please uninstall of drivers& software of printer restart pc with disconnecting printer from computer...
then install software for printer ..follow the instruction ..then when pc notify u to connect printer/harware detection then connect printer to pc & get printe on ....i am sure u r printer will be detected & install scessfully done
if this information is useful for u please Rate me.........
Jun 14, 2008 | Lexmark Office Equipment & Supplies
Printer installation problem
Please perform below steps :
1.open a Command Prompt window(click start---->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note the space after depend=) and press Enter.
Try reinstalling the printer.
Or
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
Try reinstalling the printer software. If the issue does not resolve Please get back me.
Thanks
Dec 23, 2007 | Office Equipment & Supplies
Lexmark 2500 Scanning
my lexmark 2500 scan wont work I get App4r exe problem...
Sep 04, 2007 | Lexmark All-in-One Printer with PictBridge
Lexmark X2500 All-In-One Printer Logo
216 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
