Question about LG WM-2277HW Front Load Washer
Washing machine willnto drain and I can not undo
Washing machine will not drain and I can not undo the drain basket. What do I need to do to fix this?
  • LG Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineWashing machine willnto drain and I can not undo - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 12, 2010
Any can't the Basket engage in drain step?
When the washer fills, the basket floats allowing it to engage to the wash mode, when the washer drains the basket needs to drop back down inorder to engage to the spin mode. Pleazer Appliance...
Jun 28, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Won't drain
the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump. write down the model and serial number to your washer and buy a pump. they are only about 15.00. remove the old and install the new. having a repairman like me install would cost about 150.00, so i advise you to do it yourself or have a friend help.
Jun 24, 2011 | Washing Machines
The clutch is not mechanically engaging with the basket properly
undo the main bolt under the washer pull of the brake hub undew 5 0r 6 bolts and undo 2 plugs there are coil magnets i say about 20 clean them with air and use fine grit sandpaper on the end and inside the brake drum tri that it worked for me
Sep 07, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Hotpoint washing machine WF430- Where would my filter be located as it needs to be emptied?
Its located at the rear of the machine, adjacent the drain pump, held with jubilee clips. You only have undo the main one. Filter is like a small, holed basket with a plastic ball. Empty anything in there and make sure you place the plastic ball back, tighten jubilee clip.
Jan 04, 2010 | Hotpoint Washing Machines
The washer want drain
Hi, the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump. write down the model and serial number to your washer and buy a pump. Thanks! mannu_rakesh
Aug 21, 2009 | Washing Machines
My washer dryer won't drain, is there a drain dial setting? there is a small amount of water that won't drain away. it means the door lock won't release
Apr 21, 2009 | Washing Machines
Water not draining from washing machine
the pump can be removed u need to pull the washer out tip it backwards and lean it against the worktop bend down and look undo the washer u will see some 8ml screws to undo once undone u can push backwards and twist the pump out you need to undo the pipes aswell
Sep 09, 2007 | Zanussi FLA1001W Front Load Washer
LG WM-2277HW Front Load Washer Logo
96 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
