Question about Mtd 22" Yard Machine Push Mower
I put too much oil in my 6.0 hp mtd Yard machine after changing the oil. Soon thereafter it began smoking and eventually died. Since I have purchased a new spark plug an am unsure what to do next as I have not been able to locate the air filter for inspection. I also noticed oil dripping from the carberator and am unsure what to do other than buy a used mower. I have been able to get it to start for a second or two but it again dies. Any suggestions would be greatly appreciated!
  • 6 Answers
SOURCE: I have an mtd yard man mower that wont stay
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Posted on Apr 14, 2009
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
canbruce75
  • 1776 Answers
SOURCE: GOT GASOLINE IN OIL TANK.
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Posted on Jul 15, 2009
mickey813
  • 472 Answers
SOURCE: MTD Yard machine Lawn mower. Slips and jerks while
SOUNDS LIKE THE INPUT SHAFT ON THE TRANS IS STRIPED OUT
Posted on Nov 06, 2009
I have Yard Machine 638 RL, Model 0V358EA, 13,5 hp. I want to change the Oil engine how many litter must put oil in the engine
The Tecumseh OV358EA 13.5hp takes one quart of oil, 32oz or 39oz with filter. Use 30W except if it is used in very cold climates. MTD makes a drain tool for around $5 that clips onto the drain plug area and allows you to direct the draining oil into a container with a lot less mess.
tom
Apr 26, 2012 | Mtd Garden
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
I have a mtd 6 hp push mower,what type of oil should i use for it?
Lawn mowers with engines smaller than 10 hp use a "splash" oil system for lubrication. Therefore you should use a standard SAE 30W non detergent oil. Per most user's manuals oil changes are every 25 hours of use. Every 4th oil change you can use a detergent 30W oil. Doing this will clean the inside of the crankcase and all components to the point the look brand new. It will not hurt the motor or the seals in the motor. However after this cleaning 25 hour period with the detergent oil, you should go back to SAE 30W oil again.
Kelly
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Where do i change the oil on 5.5 hp. 21 inch cut mtd push mower
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Apr 04, 2010 | Mtd 22" Yard Machine Push Mower
GOT GASOLINE IN OIL TANK OF MY LAWN MOWER BY ACCIDENT. sTARTED THE MOWER ONCE .IT STARTED BUT GAVE A GREY SMOKE AND DIED.I HAVE A MACHINE YARD MOWER FROM MTD.IT IS 22'' SIDE DISCHARGER.PLEASE...
Jul 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I bought a mtd yard machine at a yard sale today. It is a model 116-50 6f18 1A36c40219. It seems to work great except it smokes a lot. Is this normal or a problem. Thanks
well its more than likely got to much oil in it or the oil needs to be replaced usually when one smokes thats what it is or some one has glipped it on its top and all the oil is at the top of the engine if its that it will stop sooner or later
May 01, 2009 | Mtd 22" Yard Machine Push Mower
What is gas mixture for 3.5 hp engine?
do not put oil in gas just 87 octane gas their should be a small pulg or cap where you can ck. the oil.you do not mix gas and oil with that moter or it will smoke bad
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
Apr 05, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
81 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
