Question about Acer Aspire One PC Notebook
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and F12, but don't see anything that would suggest something unusual and it still shuts down when in those modes. Any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Posted on Jul 11, 2010
  • Derek_Photo Jul 19, 2010
    While the flash disk seemed to do stuff. The problem (at least with my model) remains. The netbook shuts down before windows can load. In fact if I leave the netbook on the setup screen (f2) it still will shut down.
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
The aspire 3680 will not trun on. battery will not charge. even with the charger plug in
plug unit into wall remove battery boot computer. if it boots up you will need to replace your battery
Nov 14, 2009 | Acer Aspire 3680 Laptop
My acer aspire e500 has no hard disk aactivity
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
Jul 30, 2009 | Computers & Internet
I have an Acer Aspire one model zg5- Power cord
Here is another thing you can try. Unplug the power cord, and then remove the battery. Press the "Start" button and hold for 5 seconds. Replace the battery back into the computer and plug in the power cord. Start the machine and see if the low battery message still comes up. Sometimes the program that monitors the battery status gets confused. Doing the above should straighten it out. The Acer should start up and the AC power light should be lit. Look down in your task bar for the battery Icon or go to Battery Status in Control Panel and see if it shows that the battery is charging. Even newer batteries can go bad (rare) but if this is the case and a cell has shorted out in the battery, then your only recourse is exchange under warranty.
Jul 16, 2009 | Acer Aspire One PC Notebook
Acer aspire 1640 wont boot up
TRY TAKING YOUR BATTERY OUT FOR 15 MINUTES THEN PUTTING IT BACK IN. IF IT COMES BACK ON, RECALIBRATE YOUR BATTERY BY LETTING THE BATTERY GO DOWN TO 5% THEN PLUG THE POWER CORD IN. YOUR BATTERY MAY NOT BE STRONG ENOUGH TO TURN THE SCREEN ON, EVEN THOUGH YOUR BATTERY METER SHOWS IT HAS A GOOD CHARGE. QUICK CHARGES OR FREQUENTLY UNPLUGGING IT CAUSES THE BATTERY METER TO READ DIFFERENT THAN THE AMOUNT OF CNARGE THE BATTERY IS ACTUALLY HOLDING. RECALIBRATING IT WILL GET THE METER AND THE BATTERY BACK ON THE SAME CYCLE.
Jun 08, 2009 | Acer Aspire 1642WLMi Notebook
Acer aspire 5100 won't stay on when booting on battery
replace the battery. Batteries usually only last about two years and it sounds like it just cant hold any more juice. To find a battery go to google.com and type in the model of computer and push search. Sorry for the news but its an easy fix
Dec 30, 2008 | Acer Aspire 5100 Notebook
The notebook will not boot up. When the button is pressed, it lights up for about 10 seconds and then goes off. There is a faint hum which sounds like the fan starting up but that also stops when the...
sound like you have power problem mostly that is happen to the hp notebook now to solv
now you need to unplug the ac power and also remove the battery and press the power button and hold untell the light come on and plug it back in and also put your battery back on the notebook should work normal again
Dec 10, 2008 | Acer Aspire 7720 Notebook PC
Notebook goes blank
your battery may be getting to weak to work.
try booting without the battery.
Apr 26, 2008 | Computers & Internet
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
