Question about Kenmore Refrigerators
I just installed a new water filter for my door front water dispenser and no water comes out. Kenmore Model#363.50622000 Serial # 03925072 It has an adapter which is also installed
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 1122 Answers
SOURCE: Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Posted on Mar 02, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
SOURCE: Model 363-9534753 Kenmore icemaker not dispensing ice cubes
I had the same issue and here's what I did to fix it. I pulled out my ice bin. Pushed the metal rod that's underneath it up. Pushed it back into place so that the metal rod would go above the lever in the hole in the back. Sorry- don't know any of the technical terms or names of parts, but once I readjusted the position of the rod I got ice cubes. Hope it works for you!
Posted on Apr 28, 2009
No water from dispenser
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
Dec 21, 2009 | Kenmore 56722 / 56724 / 56726 / 56729
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water comes out of the water dispenser in a trickle. Side by side model, icemaker in the door. Water filter was just replaced; water was only coming out in a trickle before replacement. Model 106.57033602
Sounds like the solinoid valve in the back of the fridge is not closing all the way.usually located at the the bottem right. replace the valve. It will have a 1/4 inch plastic hose line attached to it. shut off the water source first, then remove the valve, be sure to write down the model and serial number before you go to a appliance shop.
Jul 03, 2009 | Kenmore Refrigerators
Kenmore model #74223 water is dripping from dispenser on front of door.
Possible cause can be selenoid valve that supply water has a problem.These are really sensative to limestone and little particals even the water comes from the filter it may happen.Check it.
Jun 30, 2009 | Kenmore Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Water not coming out of water dispenser or into the ice maker
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water and ice won't work on kenmore side by side fridge
Good luck! ;)
Mar 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New filter but water dispenser still not working
Check the water valve if its working most probably watewr line inbetween the water valve and the water dispencer is frozen. Un plug the refrigarator for four hours and try again.
Mar 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
