Question about Samsung Digimax S630 Digital Camera
Samsun s630 lens is stuck out, won't turn on
The lens is stuck out, and the screen is black. ive changed the memory card and batteries. everytime i try to turn my camera on, the green light flashes once and then nothing happens. i dont know why its doing this!
  • Kri Kri Jun 01, 2008
    I accidentally dropped my sister's camera while it was still on, and the lens is still out and I can cut it on for about three seconds and then it will cut off... is there ANY way I can fix it?
  • J Noel Jun 02, 2008
    Camera will not turn on and lens is out. New batteries!
Guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Posted on Apr 21, 2008
Everytime i turn My Kodak EasyShare camera on it says "insufficient bettery" Everytime. What do I do?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Cameras
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Jan 17, 2011 | Cameras
Black screen when i turn camera on have changed the memory card, menu works and all my pictures are still there when i go to preview on old memory card, have changed the batteries also. Kodak...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 19, 2010 | Kodak EasyShare C913 Digital Camera
My cam doesnt switch on
1. Ensure batteries are fully charged.
May 13, 2010 | Kodak EASYSHARE M763 Digital Camera
Card lock.?
Friend dont worry it so simple
Insert u r card into card reader and then change its format
Up to
Fat or Fat 32 Into NTFS and format it if it is formated then it will be ok
Jul 25, 2009 | Samsung Digimax S630 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Feb 16, 2009 | Samsung S830 Digital Camera
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Olympus fe-210 fault
i think u need to change some small componnt in power board.
Jun 16, 2008 | Olympus FE-210 Digital Camera
Cameras lens stuck out and wont turn on
eject the camera battery and clean with pin your battery tip in your camera after that turn on your camera .
hope its helpful for you
Oct 16, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
243 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
