Question about Fusion ENAM60040 Car Amp
Power problem have 12v power to amp but no output and green light will not lite. Have checked 25amp fuse fuse checks good
  • 407 Answers
The best places to look are:
1. Remote wire running from fuse box or back of head unit.
2. Ground wire, make sure it is connected good the the body of your vehicle. (I almost threw away and $700 amp because the ground wasn't secure enough).
3. If equipped, inline fuses on power wire or connections on battery.
If all these check out, then its probably a short inside the amp. You can have them fixed, but sometimes it cost just as much for a new one! Hope this helps and good luck!
Posted on Jul 11, 2010
2001 gmc sierra brake lights no 12v to brake switch fuses good jumped 12v to input pressed brake 12v on output still no lights wiring issue on both sides of brake switch????
Checking the correct wire's ? Orange wire is B+ power into brake lamp switch & white wire coming out of switch . STOP LPS fuse 20 amp. under hood fuse box . Check with a DVOM - digital volt ohm meter , Tab's on top of fuse ,B+ on both side's ? find connector C-202 ,check pin's E & F , these are the wire's to an from brake lamp switch . Look at the wiring diagram here http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. Under system click on lighing , then under subsystem click on exterior lighting . Click the search button then the blue link .
C202
On the left side of the I/P on the back of the cluster
May 22, 2018 | GMC Cars & Trucks
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
02 spectra no power at fule pump and inj fuse
The pump relay should have four terminals. Number 2 is a green red wire which powers the pump from a 10 amp fuse. Number 3 goes to the pump. Number 1 powers the magnet in the relay and number 4 is the ground signal from the engine computer. If the relay does not engage on its own, one of these circuits is not working.
The injectors get power from that 15amp fuse which gets power from the main relay.
The problem could be farther upstream with the 25amp main fuse.
Feb 11, 2014 | 2002 Kia Spectra
Right side parking lights
usa car, not Renegade or export car. nor DRL lamps.
fuse, can look good but be bad.
use any ohm meter, to make sure they are good. 0 ohms good.
the car can have park-tail relay. yes, it does have a park relay
that feeds 2 fuses (#7&9) then all lamps left and right.
the BCM controls the relay. body brain.
check voltage at all 4 pins of park relay, and bingo know who is messing up,?
pins 86/87 hot 12v all the time( battery)
87a = ground 0v all times.
30 is relay output, 12v park on.
85 pin is relay coil control. 0v park, 12v not park.
if you have 0v on 85 , in park the BCM is working
there is start.
if a fuse is blown to the BCM, it will mess up
Jan 06, 2014 | 2004 Jeep Liberty
Have 12v power in but have no power out green
I would check fuses first and see if that helps
Jul 11, 2010 | Fusion ENAM60040 Car Amp
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
Jun 05, 2010 | Car Audio & Video
Trouble shooting XM-1652Z Amp
Does this amp have individual chanel fuses? these are usually found near the RCA Inputs. If so then take them out and check if they are blown. Then check the speaker outputs to make sure thee is nothing like fluff or any crossed wire strands as some of these amps have an auto cutout. The only other thing I can think of is maybe you have blown the output chips and the cost to fix is more than replacing with a new one. hope this helps
Jan 26, 2008 | Car Audio & Video
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Fusion ENAM60040 Car Amp Logo
Top Fusion Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
