Question about Sub-Zero Bottom Freezer Refrigerator
Sub-zero is not freezing
My sub-zero refrigerator is having some issues. It's a refer on top and freezer below model. The refer is working fine but the freezer is having problems freezing. The coils in the top of the freezer become covered with frost which eventually makes a fan in the freezer make noise. This is followed by the ice maker becoming jammed (no more ice production): bad for cocktails on the weekend. The problem is temporarily solved by turning off the freezer (placing the freezer items in a cooler), melting the frost, cleaning the water out of the freezer, reloading the freezer, turning the freezer on and voila' it begins working (making ice) for a week.
  • Sub-Zero Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezersub-zero is not freezing - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Freezer not working/but fan is running
The freezer side may be icing up. Soon enough the fridge side may have problems, too. Love those Sub-Zeros, but if the defrost timer fails, it will ice up. Defrost timer is up top. A generic one will do.
Nov 25, 2013 | Sub-Zero 642
1988 sub zero refrigerator's freezer is warm on the top and not making ice
Sounds like you have a fan problem around the evaporator in the freezer, it is possible it has failed and won't move air within the freezer section anymore. Cold air drops and heat rises.
Good Luck
Mar 21, 2013 | Sub-Zero 561 / F
Why would a sub zero model 650f freezer freeze up ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Water collects on the bottom of the refrigerator of model with frife on top freezer drawer below
drain is pluged with ice and may require a drain heater kit . very common problem . mm
Sep 23, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a 20 year old side by side sub zero. For the last few months i have had problems keeping the temp even in the refrigerator side, either freezes or gets too warm. Now it wont get colder than 45 or...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Sub-Zero Refrigerators
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
My 650/f sub-zero is not cooling in the refer but the freezer is working fine?
Subzero uses two compressors so the freezer is a separate system. The first thing to do is clean the condenser. You can find instructions on how in the owners manual or at subzero.com. They even have videos. If that doesn't take care of it you could have a bad condenser fan motor a sealed system issue or a temperature sensor issue. Also I have seen if you put something tall enough to push up on the light cover on the top shelf that can stop the evaporator fan at the top of the refrigerator section.
Aug 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
250 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
