Question about Cosco Metal Crib
How do you put a Cosco model 05028SNG pack and play together?
  • 17,970 Answers
Cosco baby cribs are easily assembled, with or without the instructions. You will need to know what the finished product should look like, so if you don't have the original box, look up the model online, so you know what the final assembled crib looks like. By using some simple tools at home, you will be able to assemble the crib in about an hour.
1. Find a photo or diagram of an assembled crib in the same model you have purchased. If you do not have the instructions, you will need to reference the photo for specific parts of the crib.
2. Lay out the four sides of the crib--the two shortest sides, the back panel and the front panel, or if your model has a drop-down front side, it will have hinges and/or grooves on the ends.
3. Attach the legs or foot posts to the four corners of the crib. These will require an electric screwdriver.
4. Attach each of the four sides together using the swivel casters and locks. Locate the holes to fit each of the swivel casters and put them in place. Insert the other screw through the corresponding hole on the other connecting side and, using a Phillips screwdriver, turn it so it locks in place. Repeat this for each of the four sides, so they connect in place. If you have a drop-down front on the crib, you will install only three sides.
For a drop-down front, position the long bar in the bottom front by installing the swivel casters and locks on each side. Then, screw in the gate shoe at the bottom of the bar, and the grooves on the two inside rails of the crib, going vertically. The top right (or in some cases left) side of the crib will have a latch at the top to help in taking the gate up and down.
5. Install the mattress spring support. Using a flat-head screwdriver or the electric screwdriver, screw each corner into place securely. The spring support should be completely level.
6. Install the front drop-down gate. Slide the gate through the grooves on the side panels and slide it all the way down until it clicks in place. To open and close the gate, you will need to press the side latch on the top right (or in some cases left) side of the crib in addition to pulling up on the front panel. This will elevate the side, and then you can push down to lower it all the way.
7. Put the mattress inside the crib and arrange the bedding.
You can also visit the Cosco website or the retailer from which you purchased the crib to get detailed instructions mailed or emailed to you. The number for Cosco Replacement Parts is 1-800-544-1108 from 8 am to 4.30 pm EST.
Hope help with this.
Posted on Jul 11, 2010
I just picked up a crib on side of street . I am in financial debt that I cannt afford to buy a new crib the crib I picked up is model number 10-121 manufactured in 2003 . It has no bolts no screws nothing...
Most hardware stores will have the bolts you need. Take in the headboard and ask for help
getting a set of bolts that fit. Lowes and most others will have them too. One thing you may want to do
is call Cosco and gove them the model number and date of manufacture and ask if they can email
a set of instructions to assemble the bed. This way you make sure it is safely put together.
Cosco / Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Apr 19, 2011 | Cosco Baby Gear
How i close my cosco plypen modle#05132cczj
Check the below instructions. It might not be the same same as what the manufacturer envisioned but it worked for many people.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Cosco Beatrix Potter Playard Crib
Folding up Cosco play yard
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- Cover.
Hope this helps!
Jan 06, 2009 | Cosco Beatrix Potter Playard Crib
Cosco Car Seat Model Number 22123 Instruction Manual
need instructions ASAP on how to put back together the straps, I took off the cover to wash it. It is NOT EASY to put back.
thanks,
yolanda
Sep 17, 2008 | Baby Gear
Cosco Playpen
-- Cover.
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
Cosco playard playpen
hey guys, wat you have to do is keep the middle of the playpen up, the very middle thenyou lift up all the sides until they click...once all 4 sides have locked you press the middle of the play pen down and put the mat on top :) hope this helps
May 31, 2008 | Cosco Metal Crib
Putting seat together
http://www.coscojuvenile.com/instructions/ or email consumer@djgusa.com give them your model and manufacture date & they can send you one.
Apr 30, 2008 | Cosco 02-442
Crib Instructions
Call 800-647-3876 with the model number and date of manufacture
Dec 12, 2007 | Cosco 2 in 1 10-185-WHO Crib
Cosco crib Model 80030WBO12 Lost Insturctions
Call 800-647-3876 with the model number and date of manufacture.
Nov 25, 2007 | Cosco 2 in 1 10-185-WHO Crib
Cosco metal crib assembly instructions
put together a baby bed step by step
Oct 21, 2007 | Cosco Metal Crib
Cosco Metal Crib Logo
196 people viewed this question
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
