Question about Intermatic & Indoor/Outdoor Rain Tight Timer
How to program orbit watering timer
Model 56236
How do I program model # 57114 from station a to b to c
The model of Orbit sprinkler timer you show has 4 or 6 zones for watering. I provide link below for instructions for use. Reading it, I don't think this timer has A, B, C, schedules if that's what you mean (whole different settings on each). Other timers commonly do however that feature in my experience is rarely used. If you don't like this timer, Home Depot has a $20 timer 4 station that I've found is easier to understand than many of them, also a 6 station for a little more same type (think is Orbit not sure). May need to zoom instruction shown from the link.
Jul 09, 2016 | Hardware & Accessories
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
How Do I program this timer to run at 5am and 5pm.
Question posted under photo of Orbit water timer:
Open following links for possible help identifying product and downloading manual:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
More water timer links
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Jun 05, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
How do i start timer?
Question posted under photo of Orbit timer.
Open following link to identify timer and download possible manual
May 11, 2011 | Orbit 2-Dial Hose Faucet Control Timer...
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
733 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
