Question about Garden
THis is a Husqvarna 54 inch deck 2009 model. when I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the forward pedal for it to even go slowly in reverse. I need help. I haven't had this mower very long and it has been a disappointment since I have bought it. Jul 11, 2010 - The belts are new and I dont hear any slipping of the belts. It moves very slowly and it has never moved correctly. This a pedal not a shift into gear type of mower. you press the pedal to go forward. Is there an adjustment. I cant see one. I have purged the transmission twice according to manual.
  • 6,993 Answers
can you please rephrase your question, I don't understand it.
Bye for now.
Posted on Jul 27, 2010
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
When I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the...
You didn't specify a brand or type but it sounds like a hydrostatic drive model and if so, it is 1 of 4 likely things
Drive belt from engine to transaxle slipping badly (replace the belt)
FWD-REV pedal linkage faulty
Transaxle is broken or has fluid issues (not user fixable)
by-pass rod (neutral lever/rod) is pulled out a bit. (push it in fully!)
Jul 11, 2010 | Garden
My huqvana won't go in reverse or forward
if the leaver moves freely but wont move first check belt is on pulley and if so you have sheared off keyway on the pulley on top of drive axle remove pully replace keyway reinstall
Jul 26, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The drive pedal is stuck forward and wont budge along with the brake pedal...
Drop mower deck and have a look.
Both rods run to the rear on the right side.
Possibly something interfering.
Jun 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The transmission will not engage,
it is possible that there are no parts missing - reach in and push the "rod end over the rear axle doesn't move the lever" lever forward - the brake is sticking in the "on"position - wiggle the lever back and forth, if it moves more than 1/4 inch, use a half inch wrench to tighten the nut holding the lever until the lever has only about 1/4 inch movement
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
