Question about Electrical Supplies
Ihave a single cylender 178 china yanmar diesel
Ihave a single cylender 178 china yanmar diesel engine. had water in fuel . cleaned water out of system and now I cant. get fuel pump to pump fuel. took pump out and it will pump by hand. checked cam shaft and it is turning . where to now?
    Scholar:
  • 97 Answers
These engines have a mechanical injector and when water gets in them the best way to say this has larger particals then the diesel the best way is to remove the injector and the fuel lines and spray a carb cleaner in then this will dissipate the water place the injector in a pan and heat up on a stove not to get to hot this will dry out the injector then when this is done spray wd-40 in where the fuel tube supplies the fuel do not touch the tip or bump or drop striking the tip that goes in the engine you will have to replace it then reinstall all the removed parts keep the line lose at the injector crank the engine till fuel starts flowing do not hole the ling with a finger you can blow a hole and inject fuel in to your blood these pumps build a massive pressure when lines held .
when the fuel flows start to tighten the line what your doing is purging the air out as well as any water. when you get the lines to where their is a dropping of fuel the engine should start to run it will be ruff and smoke with a wrench loosen then tighten line a couple times wile it is running then snug the line the fuel in the injector will push what rest of the air out and it will smooth out . DO NOT USE STARTING FLUID ON THESE ENGINES you can crack the case they cant take the stress. i hope this helps
Posted on Aug 31, 2010
I have a yanmar diesel tractor ym147 it will start but it goes wide open no matter what you do with throttle fuel injection pump is good what else could cause this? Injector maybe?
diesel engine always start in the full fuel position and the governor moves the rack back to idle
that indicates a stuck or broken governor in the pump so have a diesel specialist shop check it or and repair it as the pump has to be bench calibrated
Nov 11, 2017 | Cars & Trucks
How do you start a yanmar v2 750v diesel engine after bleeding fuel system ??????????
try spraying some starting fluid in it if it starts keep sprsying short sprsys in it until it catchs the desil fuel then runs
Jul 22, 2014 | Garden
What are the main manufacturers of diesel engines for boats?
he main manufacturers of diesel engines for boats: Caterpillar Marine, Cummins Mercruiser, Detroit Diesel, John Deere, MAN, Westerbeke, Mecruiser Diesel, John Deere, Volvo Penta, and Yanmar.
For more information on these manufactures, check out these websites: http://marinefuel.com/marine-engine-manufacturers-diesel/ and http://www.discoverboating.com/buying/types/engines.aspx?id=80
Feb 06, 2013 | Boating
I am looking for a kinki waterpump on yanmar diesel engine
Which kind of kinki impeller you need?We have the KINKI BK-0132 and BK-0134
Flexible Rubber Impellers replace KINKI impeller BK 0132 BK0132 Neoprene Flexible Rubber Impellers replace Kinki Impeller BK 0134 Neoprene
I hope which can help you:-)
Best regards from Vera
Flexible Rubber Impellers Mfg Co.,LTD
No.285 Yunshan Rd,National Hi-Tech zone
Ningbo 315040,China
Tel:+86-574-66850926
Fax:+86-574-66850926
Email:sales@flexible-impeller.com
http://www.flexible-impeller.com
Aug 27, 2011 | Computers & Internet
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do you check/adjustthe diesel injection timing
You should not have to adjust the timing.If it's not running good then you either have a fuel problem[plugged fuel filter or leaking rubber fuel lines]or you need to check the injecters.To check them start the engine and loosen the injecter lines on the injecters one at a time to determine which injecter needs to be replaced.The injecter that makes no differance to the way the engine sounds is the one you need to replace.
Nov 26, 2009 | Garden
Yanmar diesel engine model#3007D003 powering a 6x4 cuts off.
My thought is that it is electrical, since it will not crank. I assume you mean that it will not turn over when you turn the key. I am not certain, but I think that if you have an electrical problem it may shut off the fuel supply as well. There is probably an electrical fuel stop on that machine. Since there is no spark plugs or electrical system to make the engine run, by shorting out the electrical system it will not stop the engine.
Oct 26, 2009 | Garden
Electrical Supplies Logo
271 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
